ltljohn Posted June 11, 2011 Share Posted June 11, 2011 I wanted to find a way to power my FRS radio from the bike instead of always having to carry extra batteries. The radio uses a 650 mA battery pack or 3 AA batteries. I found a car charger with variable outputs from 1.5 to 12 volts with a 1 amp output. I then cut out some scrap plastic that is about the same thickness as the battery pack using a couple of terminals as contacts I made an insert for the radio. This is the car charger dismantled Used a Dremel tool to make room for the connectors and wired it up A little notch in the cover so I don't pinch the wires. Trim all the wires to fit and find a way to keep the adapter from shorting to anything and I am all set. Installed it all in the glove box and it works great. If I want to use the radio separately I can put the battery pack back in. It's not elegant but it works for a one off Saturday morning project. Total cost was $24 I bought 3 chargers at $6 and some change each plus shipping from Amazon the rest was already in my garage. I bought 3 because I will be doing 2 bikes and I wanted one to experiment with. Link to comment
johnlt Posted June 11, 2011 Share Posted June 11, 2011 OR................... get a Kenwood 3101 with the Autocom faux battery pack and it gets powered through the normal Autocom hook-up. No extra wires. Been working on several bikes for years. Link to comment
