twstm Posted August 21, 2011 Share Posted August 21, 2011 I just bought a R1150RT and want to mount my Garmin 2820 GPS. Where is the best mounting point? I have several ram mounts, I'm looking at may maybe one of the handlebar mounting bolts...This way I could have it dead center. Anybody have suggestions? Link to comment
Dallas Posted August 21, 2011 Share Posted August 21, 2011 I tried one of the handlebar mounting bolt RAM ball mounts when I first got my 2720. It was too low. Took my eyes off the road too long to look down. If raised up on a longer RAM arm it would start to block the view of the warning indicators. Also if using a tank bag then that also started to interfere with the view of the GPS! That RAM-mount RT handle bar bolt replacement now resides on my wife's GS as a mirror mount RAM ball.... But, if you asked me to recommend a RAM compatible way to do what you want and have the GPS dead center on your 1150RT--which I'm a big fan of, as well! Then I'd say check into the Migsel mount. It attaches pretty simply under the windshield cowling and you can attach up to three RAM balls. Then put the GPS dead center and all you have to do is glance down at it. This setup has worked for me for over 20k miles and my new 665 resides in the same location. As high up as I can get it and still lower the windshield down to the stops. Hopefully this image works! You can see the Migsel mount attached under the cowling. It simply replaces two of the stock screws. This is an old photo. Since then I've added the additional two RAM balls (note the circular black plastic insert to the left of the GPS--that covers the hole where the RAM ball screws into). Good luck! Link to comment
twstm Posted August 21, 2011 Author Share Posted August 21, 2011 I tried one of the handlebar mounting bolt RAM ball mounts when I first got my 2720. It was too low. Took my eyes off the road too long to look down. If raised up on a longer RAM arm it would start to block the view of the warning indicators. Also if using a tank bag then that also started to interfere with the view of the GPS! That RAM-mount RT handle bar bolt replacement now resides on my wife's GS as a mirror mount RAM ball.... But, if you asked me to recommend a RAM compatible way to do what you want and have the GPS dead center on your 1150RT--which I'm a big fan of, as well! Then I'd say check into the Migsel mount. It attaches pretty simply under the windshield cowling and you can attach up to three RAM balls. Then put the GPS dead center and all you have to do is glance down at it. This setup has worked for me for over 20k miles and my new 665 resides in the same location. As high up as I can get it and still lower the windshield down to the stops. Thanks for the quick reply. Is there anywhere in the USA to get the Migsel mount? Tell me about your Sirius radio setuo! I have an XM antenna I can route through my Garmin 2820...what type of headset or speakers are you using? Hopefully this image works! You can see the Migsel mount attached under the cowling. It simply replaces two of the stock screws. This is an old photo. Since then I've added the additional two RAM balls (note the circular black plastic insert to the left of the GPS--that covers the hole where the RAM ball screws into). Good luck! Link to comment
Michaelr11 Posted August 22, 2011 Share Posted August 22, 2011 I just bought a R1150RT and want to mount my Garmin 2820 GPS. Where is the best mounting point? I have several ram mounts, I'm looking at may maybe one of the handlebar mounting bolts... I've got a 2610 in the RAM cradle (same shape as the 2820) and I use handlebar mount bolt/ball. It works. Link to comment
Caddis Posted August 22, 2011 Share Posted August 22, 2011 +1 on the Migsel mount. One came with the bike when I bought it, so I can't say that I have tried other options, but it seems to work well. Link to comment
twstm Posted August 22, 2011 Author Share Posted August 22, 2011 +1 on the Migsel mount. One came with the bike when I bought it, so I can't say that I have tried other options, but it seems to work well. Where can I buy this mount? Link to comment
wbrissette Posted August 22, 2011 Share Posted August 22, 2011 http://www.migsel.com/store/index.php?_a=viewCat&catId=7 I love mine. Had one on the 1150, and bought one for the 1200RT. You use to be able to purchase them at Cycle Gagets before they shut down. The prices at migsel.com seem a bit high compared to what Cycle Gagets sold. Hopefully somebody else here in the US sells them. Wayne Link to comment
twstm Posted August 22, 2011 Author Share Posted August 22, 2011 http://www.migsel.com/store/index.php?_a=viewCat&catId=7 I love mine. Had one on the 1150, and bought one for the 1200RT. You use to be able to purchase them at Cycle Gagets before they shut down. The prices at migsel.com seem a bit high compared to what Cycle Gagets sold. Hopefully somebody else here in the US sells them. Wayne I miss Cycle Gadgets... Link to comment
Bill_Walker Posted August 23, 2011 Share Posted August 23, 2011 The Gadget Guy mount is the best one I've found. Not cheap, but great! Link to comment
BriSco Posted August 23, 2011 Share Posted August 23, 2011 I searched and only found a shop in the UK. Price was a bit lower, but their shipping killed it. Bought mine direct from Migsel. I had tried several other mounting methods, but the Migsel is absolutely the best for me. I really like it as it is solid, and puts my gps (Nuvi 550) right it my line of site. +1 on the Migsel mount. One came with the bike when I bought it, so I can't say that I have tried other options, but it seems to work well. Where can I buy this mount? Link to comment
tazplas Posted August 23, 2011 Share Posted August 23, 2011 I made mine out of 5mm ali and a RAM ball. It's been painted black since and looks like it belongs. cheers Steve Link to comment
MikeRC Posted August 23, 2011 Share Posted August 23, 2011 A couple of previous threads with a few photos here: 1150RT GPS mounts 1 and 1150RT GPS mounts 2 I have a Zumo on the Gadget Guy system and it works pretty well. But I think any system that mounts to the windscreen subframe vibrates a bit more then when attached to the handlebars or main frame. But I like the GPS higher and in the middle so that I can still see all the lights & gauges. I have had a GPS on the handlebars before and it interfered with lock-to-lock turns and the tank bag. So it really depends where you want it, if you use a tank bag and how you will wire it. Mike Cassidy Link to comment
