FLrider Posted September 1, 2011 Share Posted September 1, 2011 I bought a tire changer recently, thinking I might save a few bucks in the long run. Between the 3 bikes, utility trailer and boat trailer, I go through a fair amount of tires. Anyway, I bought a ProHoist changer that comes with the motorcycle attachment. However, the "arms" where the wheel is supposed to sit, doesn't have anything to keep the rim from getting scratched. See Photo tire changer clamp top view small I suppose I could have zipped tied some garden hose or some other plastic material to the arms but I wanted something more appropriate. I found these Mojo blocks on an internet search. As it turns out, they are distributed by one of our own members. I guess they were originally designed for the Harbor Freight tire changers but I think you can make them work on just about any tire changer. You can find the details here: http://home.comcast.net/~prestondrake/mojoblocks.htm So, what I wound up doing was buying some flat steel. After lining up the mojo blocks to the back of the arm, I put the flat steel under it, marked it, drilled it and tapped it. I then tack welded the steel to the arm and screwed in the mojo blocks. Piece of cake. This is how it turned out. Untitled Untitled by AFineRide, on Flickr Untitled by AFineRide, on Flickr Untitled by AFineRide, on Flickr Now all I have to do is dab a little paint back on where I had to sand it down for the weld. I'm hoping the bike rims will actually fit in that "curve" of the mojo blocks. Photo 4. I am also hoping that none of the rim will make contact with the flat steel. If they do, I think it would be easy enough to just put a piece of thin rubber material on the flat steel part. I'll report back when I do the next tire change. Link to comment
tallman Posted September 1, 2011 Share Posted September 1, 2011 The mojo's are position sensitive. You've got the A in the C position. B is OK. So swap the other 2 and you'll be good to go. Link to comment
FLrider Posted September 1, 2011 Author Share Posted September 1, 2011 The mojo's are position sensitive. You've got the A in the C position. B is OK. So swap the other 2 and you'll be good to go. Tim, are you screwin' with me again ! ? Now you are going to make me go look. I think all three are identical. Link to comment
tallman Posted September 1, 2011 Share Posted September 1, 2011 Who me? Sorry, couldn't resist. I bad. Enjoy your new tool, you'll find new friends, or should I say new friends will find you. Link to comment
Joe Frickin' Friday Posted September 2, 2011 Share Posted September 2, 2011 Nice work. I'm hoping the bike rims will actually fit in that "curve" of the mojo blocks. Photo 4. I am also hoping that none of the rim will make contact with the flat steel. They should fit the groove nicely; it's sized to accomodate the extra width of the lip on outside-spoked GS rims. As long as you're careful about initally putting the rim into the Mojoblocks, they shouldn't make contact with the metal parts of the stand (note that the bottom of each block extends out just a bit farther than the top). Link to comment
FLrider Posted September 2, 2011 Author Share Posted September 2, 2011 Nice work. I'm hoping the bike rims will actually fit in that "curve" of the mojo blocks. Photo 4. I am also hoping that none of the rim will make contact with the flat steel. They should fit the groove nicely; it's sized to accomodate the extra width of the lip on outside-spoked GS rims. As long as you're careful about initally putting the rim into the Mojoblocks, they shouldn't make contact with the metal parts of the stand (note that the bottom of each block extends out just a bit farther than the top). There he is ! Hey, thanks for the install tips and quick delivery. I didn't know you distributed mojo levers. I had already bought mine before I found you and the mojoblocks. I've gotten pretty good at changing tubeless tires. Have not tried to replace the rim locked, tubed tires on the Enduro yet... Link to comment
Fubar Posted September 3, 2011 Share Posted September 3, 2011 Enjoy your new tool, you'll find new friends, or should I say new friends will find you. I think FLRider just saved me $80-100 on my next change of online purchased tires. Link to comment
tallman Posted September 3, 2011 Share Posted September 3, 2011 If you build it they will come. Or something like that.... Link to comment
FLrider Posted September 4, 2011 Author Share Posted September 4, 2011 Enjoy your new tool, you'll find new friends, or should I say new friends will find you. I think FLRider just saved me $80-100 on my next change of online purchased tires. Sure! C'mon down (up in your case). Link to comment
