stevebsa Posted September 16, 2011 Share Posted September 16, 2011 Would anyone have the fuse layout or diagram showing the fuses for my 2004 R1150RT-P ? Thanks for the help! Steve Link to comment
Dave Faria Posted September 16, 2011 Share Posted September 16, 2011 What are you trying to do??? Depending on the municipality the RTPs are built with different options. I have the BMW CDROM with generic wiring diagrams. They are, unfortunately, not able to be copied as a file(there may be legal problems as well) and if printed as a 8.5x11 you cannot read the detail. If you know which fused circuit you are tring to fix or add to I may be able to send you a window of that small area of the drawing by email. If you are planing on keeping the bike you might want to buy the CDROM I have. I got it from the dealer and it costs abt $60. BMW part# 01797720399 / SLP 2.2. The disk says it cvers all BMWs from 1993 to 2008. Link to comment
biometrics Posted September 16, 2011 Share Posted September 16, 2011 The fuse layout should be in your owner's manual. If you don't have one, then this PDF file should help you... but do please tell us what the issue is that you are dealing with... you will likely get some sage advice on how to deal with it. Link to comment
biometrics Posted September 16, 2011 Share Posted September 16, 2011 Here is a second PDF that may be even more help since it is for an R1150RT-P Link to comment
stevebsa Posted September 16, 2011 Author Share Posted September 16, 2011 Thanks for the help---that's my first post---can't believe the quick response! Much better than old Volvo forums! I had a blown horn fuse which I was able to track down with my meter. Just wanted the diagram for future help if I have a problem. The 2 PDF files were great to receive, had all the info I needed. The small operators manual that I got from the dealer didn't show the fuses. Thanks again for your help. Steve Link to comment
biometrics Posted September 17, 2011 Share Posted September 17, 2011 Glad to be of help. Link to comment
