KDeline Posted September 20, 2011 Share Posted September 20, 2011 I want to circulate fresh oil without starting the engine for the winter shutdown. Yea I'm becoming more anal. Instead of pulling the 4 plugs and grounding them, is the connection on top of the injector a controller? If I pull this off will the injector not fire a gas charge? This is on a 2007 1200 GSA. Is there a better way then this to spin the engine with the starter and not start it? Link to comment
dirtrider Posted September 20, 2011 Share Posted September 20, 2011 Evening KDeline Yes, you can un-plug the power wire on each injector then crank the engine. By unplugging the power wire to each injector it can’t/won’t spray any fuel when cranked. Link to comment
KDeline Posted September 21, 2011 Author Share Posted September 21, 2011 Thank you sir! Link to comment
ESokoloff Posted September 22, 2011 Share Posted September 22, 2011 Evening KDeline Yes, you can un-plug the power wire on each injector then crank the engine. By unplugging the power wire to each injector it can’t/won’t spray any fuel when cranked. Can you not accomplish the same thing by cranking with the side stand down? Link to comment
cris nitro Posted September 22, 2011 Share Posted September 22, 2011 Evening KDeline Yes, you can un-plug the power wire on each injector then crank the engine. By unplugging the power wire to each injector it can’t/won’t spray any fuel when cranked. Can you not accomplish the same thing by cranking with the side stand down? +1 Link to comment
StroupDog Posted September 22, 2011 Share Posted September 22, 2011 Evening KDeline Yes, you can un-plug the power wire on each injector then crank the engine. By unplugging the power wire to each injector it can’t/won’t spray any fuel when cranked. Can you not accomplish the same thing by cranking with the side stand down? +1 -2 Link to comment
KDeline Posted September 22, 2011 Author Share Posted September 22, 2011 Evening KDeline Yes, you can un-plug the power wire on each injector then crank the engine. By unplugging the power wire to each injector it can’t/won’t spray any fuel when cranked. Can you not accomplish the same thing by cranking with the side stand down? +1 -2 Mine starts with the side stand down, in neutral. In gear it will not crank. I don't know of a way to crank the motor without disconnecting something. Older bikes would spin up with the kill switch off. Link to comment
dirtrider Posted September 22, 2011 Share Posted September 22, 2011 Can you not accomplish the same thing by cranking with the side stand down? Nope, not on the 1200 hexhead. Link to comment
ESokoloff Posted September 23, 2011 Share Posted September 23, 2011 Can you not accomplish the same thing by cranking with the side stand down? Nope, not on the 1200 hexhead. Damn progress Link to comment
