pnhmpm Posted October 24, 2011 Share Posted October 24, 2011 I just replace a Z6 punctured by a roofing nail with a Z8. I noticed this evening after yesterdays ride that I have picked up a small screw in the new tire and it has a slow leak. The dealer would not repair the first tire and probably won't repair this one either. Should I have it repaired or should it be replaced. Link to comment
dirtrider Posted October 24, 2011 Share Posted October 24, 2011 Evening pnhmpm It's pretty well up to you. Personally if it were my tire & the puncture wasn't in or real close to the side wall & didn't damage a cord I would repair it & ride on worry free. If you want the correct answer for your Z-8 tire try calling Metzler tec help line & ask the people that developed & tested the tire. Link to comment
oldironhead Posted October 24, 2011 Share Posted October 24, 2011 I agree with dirtrider. Just because the dealer won't repair a tire doesn't mean the tire is not repairable. Just because the manufacturer won't recommend repairing a tire also doesn't mean the tire is not repairable. If you are hesitant to try it yourself, seek out some independent shops. I bet there are some around that can and will repair it, if it is repairable. Link to comment
BerndM Posted October 25, 2011 Share Posted October 25, 2011 Could you possibly put a tube in it? I know some tires will allow this. Link to comment
