RockBottom Posted November 9, 2011 Share Posted November 9, 2011 The Garmin Lifetime Updater program tells me new maps are available. But when I try to install them on my Zumo 220, I get the message, "Your device does not have enough space for this region. Select a smaller region." It doesn't matter what region I select from the list--same error message. I have a 4 GB SD card installed which is almost empty, but the updater program doesn't give me the option of putting it there. Any ideas? Thanks. Link to comment
Boffin Posted November 9, 2011 Share Posted November 9, 2011 Update to yourcomputer only - you need to have your GPS attached to authorise the dwnload. Once downlaoded, select the relevant map areas from Mapsource to load to your GPS. Andy Link to comment
RockBottom Posted November 9, 2011 Author Share Posted November 9, 2011 I manually deleted the map file on the unit then installed the new maps. That worked. Link to comment
RockBottom Posted November 10, 2011 Author Share Posted November 10, 2011 Par for the course--Garmin tech support didn't offer this simple solution. Instead they provided a canned answer on loading maps that showed that they didn't actually read my email query. Link to comment
