Casey Posted February 20, 2012 Share Posted February 20, 2012 Here's the background: Admore LED lighting kit installed into my Givi V46 topcase. Turn signals, brake lights and running lights. I've got 12V power for the kit coming from the red/green wire going to my rear aux plug. So far, everything works, but when I turn the bike off the kit stays lit for about 1 minute. The LED lights also come on (and stay on) when I plug into either the front or the rear accessory plug with my Optimate 4 battery charger. A few questions: Am I tapping into the right +12V wire for power? Would tapping into a different wire stop the lights staying on? If so, which wire/where? I've not ridden with the Admore light kit installed. Will it freak the CANBUS out and cause the yellow triangle to light up? I did a search using Admore with no luck about which color/location of wire to use. Thanks in advance for your time and help. C Link to comment
Casey Posted February 20, 2012 Author Share Posted February 20, 2012 Update - Conversation with Admore. I left a voicemail with Admore this morning, and was called back a couple of hours later. They said that the CANBUS system doesn't supply steady +12V power to the tail lights, but pulse modulated power to the lights when needed. The rear aux port's power shuts down approx. 1 minute after the key is turned off. So the only other options are to a) - tap into a wire in the front for the switched power. b) - install a fuse panel. c) - accept the light staying on for about a minute. So I think I'll go with c until a later date. If I ever install a fuse panel I'll reroute the power wire to it. Until then, I guess the lights will stay on for about a minute. When I plug into my battery charger, I'll just disconnect the harness from the topcase. Thanks for the replies and assistance. And thanks to Admore for the customer service. DC Link to comment
