kltk165 Posted June 12, 2012 Share Posted June 12, 2012 Had the following bag made for the BMR 49L Top Case Rack by Road Ready Motorcycycle Luggage . Really nice bag, waterproof and Made In USA. Outside dimensions are 22"x11"x9". Link to comment
Albert Posted June 12, 2012 Share Posted June 12, 2012 That's a nice looking bag. Does the bag have to be full to maintain the shape like you show in your pictures? Link to comment
Bill_Walker Posted June 12, 2012 Share Posted June 12, 2012 Nice bag, but I'd be very careful of overloading it. I'm pretty sure that just what I pack in my top case exceeds the rated load limits of the case and rack. Adding another bag on top of the case could far exceed the limits. Pack only light stuff in there! Link to comment
kltk165 Posted June 13, 2012 Author Share Posted June 13, 2012 The bag is fairly rigid. While it doesn't have to be full to maintain its shape (The bag is empty in those pics) if you put weight on top of it it will collapse. Agreed on the possibility of overload. If I load up my 49L top case liner with clothes it comes in at about 20lbs. Rated load as per BMW is 22lbs. I'm hoping BMW did their usual job of over engineering it's equipment and that the rack the top case mounts too can handle 30+ lbs. Link to comment
tallman Posted June 13, 2012 Share Posted June 13, 2012 Nice bag, but I'd be very careful of overloading it. I'm pretty sure that just what I pack in my top case exceeds the rated load limits of the case and rack. Adding another bag on top of the case could far exceed the limits. Pack only light stuff in there! I actually weigh my loaded bags before each trip and have a check list with the weight of general items. Have gotten pretty good at distribution, ususally w/in 1/2# or so on each side. Same w/GIVI which I try to underload and keep things needing ready access like rain gear, gloves, cameras, etc. And we're generally packing for two. Good luck. Link to comment
Bud Posted June 13, 2012 Share Posted June 13, 2012 Tim, Why do you purposefully underload your Givi? Trying to keep weight low? The R 1100 R I just bought has a 55 L Givi which is big enough for t full face helmets and room left over. It is on a Givi mount, which doesn't seem to be as stiff as the BMW topcase rack. Link to comment
tallman Posted June 13, 2012 Share Posted June 13, 2012 I think the GIVI is rated at 10kg, would have to go back and check. Over the years we've developed a system of loading the bag liners in a certain way so that I don't have to open saddlebags at stops, just the GIVI. My GIVI is mounted differently than yours, it has two metal side rails that attach to severl points on the bike frame and the rack then is bolted to those rails. Prolly the strongest top case mounting design system available. Personal choice for us about what conveniences we want available w/out opening side cases. W/2 of us, I carry a variety of gear, liners, gloves, depending on destination and time of year. I'll put rain gear in a plastic bag, gloves in a plastic bag, camera gear, etc. If we have to stop to add or change gear it is accessible and ez to find. The bags keep items separate and dry. For day trips ours holds 2 helmets plus a bunch too. We carry microfiber clothes and other lightweight gear. By keeping weight down, if needed, I can take rain gear and put it in H2W mesh bag on topcase luggage rack and have room and weight available to add something to the GIVI. Link to comment
