bobmorris Posted June 25, 2012 Share Posted June 25, 2012 Have run into a problem direct wiring my Garmin Nuvi 1350 to my R1200 RT-P battery using a Powerlet PPC -015 wiring set up. I find that the Garmin will not trigger the unit charging system, I understand that there is a work around that solves this problem. Can any one help me out with this? Bob Morris Link to comment
hopz Posted June 26, 2012 Share Posted June 26, 2012 Bob (?) is this Bob Morris of Florida fame? But I digress... I do not understand your question. If you find a 12 volt source it should operate the GPS when the 12 volts are present... no matter if you are running through a powerlet or fuse box or any thing else. and... I do not understand "Garmin not triggering the unit charging system" the Garmin will charge when 12v is present... no triggering involved. Link to comment
Powerlet Posted June 28, 2012 Share Posted June 28, 2012 Bob, give me a call at 877.752.7835 and we can figure out what the issue is. Davin Link to comment
bobmorris Posted June 28, 2012 Author Share Posted June 28, 2012 Davin: Picked up todays mail and there was a replacement PPC 15 cable. I immediately hooked it up and every thing worked just like it is supposed to. My many thanks to Powerlet for their prompt assistance and the issuance of a replacement unit. Bob Morris Link to comment
