kiki231 Posted July 12, 2012 Share Posted July 12, 2012 Just a quick post to share my conversion on the Q2 Pro from the stock helmet speakers to a 3.5 mm jack so i can use earphones of choice. I know this has been done on the old Q2 with posts but there are a few points of interst i thought i would share. (Photos will follow) First, the wires can be stripped by burning off the insulation with a micro-torch. Just a quick pass will light them off. I also soldered the wires after spreading the jack clamp tabs to make some space. After finishing and applying a gently bend on the clamp, i gobbed some gel superglue into the jack where the wire exits to prevent the wires from pulling out. Secondly, i have found (after spending a lot of dough and trying all different kinds) that skullcandy "Inkd" earbuds are exceptional value for both attenuation and sound quality. Third, I use my ipod directly wired to the headset. I bought a bluetooth dongle in my gen4 nano, but the music will not start after a phone call interupts the music without re-starting a pairing. I will need to figure out that problem. The sound quality on the nano is only slightly degraded, but the volume level is great. I set all volumes at slightly below half, and if my RT shield is up, with the skullcandy's the sound is excellent-- bright and clear. Very pleased, and will be even moreso when the ipod bluetooth is straitened out. Link to comment
kiki231 Posted July 12, 2012 Author Share Posted July 12, 2012 also-- the wires-- L - RED L + GREEN R - RED STRIPE R + BLUE the other 2 wired ( GOLD and BLUE STRPE ) are not used for sound-- i blieve they are part of the FM antenna system-- this may be a consideration for you-- i have a gen4 ipod-- which has a decent FM radio built in. Link to comment
