willbiz Posted August 13, 2012 Share Posted August 13, 2012 hello- I have an experience person willing to strip the factory powder coating from my 99 rt wheels and polish them our to a chrome like finish. should i have any problems getting them re-balanced? Link to comment
azccj Posted August 13, 2012 Share Posted August 13, 2012 No, I can't see any reason why they can't be rebalanced once the polish job is done. Link to comment
OoPEZoO Posted August 13, 2012 Share Posted August 13, 2012 I haven't balanced a motorcycle wheel/tire in over 60k miles (including TKC knobbies on my GS) and haven't had any ill effects. I still get nice even wear, and haven't had any vibration or handling issues. I think its a waste of time and effort. Link to comment
tomk99r11 Posted August 13, 2012 Share Posted August 13, 2012 Why would you? The wheel doesn't know, nor does the tire. Link to comment
eddd Posted August 13, 2012 Share Posted August 13, 2012 I haven't balanced a motorcycle wheel/tire in over 60k miles (including TKC knobbies on my GS) and haven't had any ill effects. I still get nice even wear, and haven't had any vibration or handling issues. I think its a waste of time and effort. Initially I followed the advice of some that believe balancing is not needed, but on one new rear tire it was very obvious that there was a balance issue. I remounted 180 degrees and it got slightly better. That is when I purchased a balancer. After balancing the tire was fine. After that experience I balance every tire. It takes very little time and the cost is minimal. Link to comment
Big_Gray Posted August 13, 2012 Share Posted August 13, 2012 I haven't balanced a motorcycle wheel/tire in over 60k miles (including TKC knobbies on my GS) and haven't had any ill effects. I still get nice even wear, and haven't had any vibration or handling issues. I think its a waste of time and effort. Initially I followed the advice of some that believe balancing is not needed, but on one new rear tire it was very obvious that there was a balance issue. I remounted 180 degrees and it got slightly better. That is when I purchased a balancer. After balancing the tire was fine. After that experience I balance every tire. It takes very little time and the cost is minimal. I am kind of with eddd on this one. I bought a Marc Parnes balancer quite a few years ago when I decided to mount the first set of replacement tires on the RT. Surprise... I did an initial test on my rims with no tires prior to mounting. Front wheel was perfect. Rear was 2 grams off (and still is). I still balance the rim prior to mounting new tires. When I mounted my last set this spring, I forgot to balance prior to putting the wheels back on the bike. I was going to remove them again and balance but I remembered the anecdotal testimonials on this board and said "what the heck" "I'll try it without balancing". At 110 km/hr, the motorcycle felt buzzier than I ever remember it in the past. I then removed the wheels and re-balanced them. The result was smooth, or at least as smooth as my boxer ever gets. I can't draw any real hard conclusions from this other than an imbalance of about 2 grams (+/- whatever imbalance was in the tire)was definitely noticable to me, even if it was only in my head but I'm sure I felt it lower down in my body. For the extra time it takes me (5-10 minutes) I am going to continue checking the balance each time the wheels are off the motorcycle. Link to comment
Big_Gray Posted August 13, 2012 Share Posted August 13, 2012 hello- I have an experience person willing to strip the factory powder coating from my 99 rt wheels and polish them our to a chrome like finish. should i have any problems getting them re-balanced? Just a thought... what were you planning to do to the polished wheels to prevent the exposed alloy from oxidizing to a dull finish? I am not trying to be smart, I just believe you would need a protective coating and was curious what you might use. Link to comment
