Twinsig Posted August 20, 2012 Share Posted August 20, 2012 Non commuter, some semi spirited riding. Southeastern U.S. climate. 2012 1150RT Recommendations? Link to comment
Don Beissel Posted August 20, 2012 Share Posted August 20, 2012 I would recommend that tires are one of the last thing you want to skimp on on a motorcycle.... IMHO Link to comment
lkchris Posted August 20, 2012 Share Posted August 20, 2012 It must have cost a fortune to own a 2012 R1150RT. Link to comment
Paul Mihalka Posted August 20, 2012 Share Posted August 20, 2012 Going around all the smart remarks, I have not read anything bad and a lot of good about Shinko Raven tires. I have not tried them because they don't fit my R1200GS. Motorcycle Superstore 170/60-17 rear $107.99 PS edit: R1150RT or 2012 R1200RT? 180/55-17 $113.99. Link to comment
BarrieSalvanda Posted August 20, 2012 Share Posted August 20, 2012 Hi There, I ran the Shinko tires on my R1150RT,good grip wet/dry + lasted.Cost wise here you get two Shinko Tires against one from big name brands. Barrie Salvanda. Link to comment
Twinsig Posted August 21, 2012 Author Share Posted August 21, 2012 Yeah i noticed the shinkos and may give em a try. My budget is real tight. And.......sometimes it's difficult to type correct with this Droid. It's my only internet source. Private school isn't cheap these days (my budget issues) but we all have different priorities huh... I just wish i had the time and resources to check the forums for more typos Link to comment
BIWOZ Posted August 21, 2012 Share Posted August 21, 2012 Another vote here for Shinko which bought the technology and moulds from Yokohama, a brand previously well known (in Australia, at least) for tyre longevity. Link to comment
Downs Posted August 21, 2012 Share Posted August 21, 2012 Shinko hands down. I've ran the Ravens on a Bandit 1200, SV650, R1150R, and FJR and they simply work great. Good grip usually last 10,000 or more miles, and no funky handling issues. I've tried the Shinko Verge on the last two bikes I've had the FJR and the FZ6 and they also work/worked really good. They seem to have better turn in and slightly better grip than the Ravens but I was getting the same mileage out of them. Link to comment
Twinsig Posted August 21, 2012 Author Share Posted August 21, 2012 Thanks for the info boys. Link to comment
jbr7t Posted August 21, 2012 Share Posted August 21, 2012 I've stuck with the Michelins. On my 3rd set with 10k plus each set. This last go around I did look at the Shinkos because of the cost. Saw some reviews talking about tread separation etc. Anyway, I decided to shell the couple extra dollars for Michelins. As someone mentioned earlier, tires are the last place I want to skimp or experiment. Ultimately that made my decision. Link to comment
Downs Posted August 21, 2012 Share Posted August 21, 2012 Every tire is going to have issues. The PR3s had a few cases of failures early on but that cleared up quickly. I've never had a tread failure on my Shinkos but then again I've never had a tread separation on any tire in around 300k miles. I'd imagine that they don't fail at any greater rate than any other mass produced tire out there. Link to comment
Paul Mihalka Posted August 21, 2012 Share Posted August 21, 2012 The Shinko 705 bias ply GS style tire had tread separation problems. Shinko switched to the 705 radial and no more problems. I've ridden them. Link to comment
jfremder Posted August 21, 2012 Share Posted August 21, 2012 Shinko hands down. I've ran the Ravens on a Bandit 1200, SV650, R1150R, and FJR and they simply work great. Good grip usually last 10,000 or more miles, and no funky handling issues. I've tried the Shinko Verge on the last two bikes I've had the FJR and the FZ6 and they also work/worked really good. They seem to have better turn in and slightly better grip than the Ravens but I was getting the same mileage out of them. I've been happy with 4 rears and two fronts using the Shinko Ravens Link to comment
g_frey Posted August 21, 2012 Share Posted August 21, 2012 Shinko ravens a good choice Link to comment
lkchris Posted August 21, 2012 Share Posted August 21, 2012 Shinko ravens a good choice A Chinese motorcycle to match a good choice? Link to comment
philbytx Posted August 21, 2012 Share Posted August 21, 2012 I'm a little confused . What, exactly, was the gist of your comment? About Shinko! Link to comment
g_frey Posted August 22, 2012 Share Posted August 22, 2012 As I understand it someone went to Japan and bought the Yokohama motorcycle tire factory and tires and took it back to Korea. So the Shinkos are Yokohamas Maybe?? Anyway I was surprized and pleased with my first Ravens and I am on set number 3. They are as good as any tire I have tried for longevity and the cost for the first set was unbelievably low at $135. The low side? somewhat noisy at times and grooved roads make front tires feel funny at times. Link to comment
St0mp Posted August 22, 2012 Share Posted August 22, 2012 i like my avon storms on my r1100rt. Just got to keep a close eye on air pressure. I neglected that on the first set. I had needless to say front started getting flat spots. Put on a 2nd set and so far i have had 0 issues been on storms sense. They came out with a storm 2 now. I have not tried but they say 17% more miles. Been getting 10-12k dont think i need any new tires until next year. have owned it for close to 7 years. Bought the bike changed over to avon the first year i had it and been avon sense. The tires dont really lose pressure. my bikes has always been kinda small compared to this rt. i had the bad habit of only checking air at the start of the season. i quickly learned... anyway Z rated tire they feel really good around turns and do a decent job during rain if you get stuck in one. safety first dont go cheap. get quality you only have 2 between you and the road get good ones. Link to comment
DaveinNCMn Posted August 25, 2012 Share Posted August 25, 2012 Another +1 for Shinkos. Put on a Raven on the rear about 2,500 miles ago. No problems so far.. . Link to comment
Polo Posted August 25, 2012 Share Posted August 25, 2012 A while back I put on a set of Continental Road Attacks. I don't remember which, but either the front or back was made in Korea, the other one in Germany. I loved them. Nothing wrong with Korean manufacturing. A lot of good stuff is made in Korea. Well except a real Martial Art. Link to comment
terryofperry Posted August 25, 2012 Share Posted August 25, 2012 Polo my friend: "Though there are many paths At the foot of the mountain, All those who reach the top See the same moon." All good natured ribbing. Terry Link to comment
Downs Posted August 26, 2012 Share Posted August 26, 2012 Shinko ravens a good choice A Chinese motorcycle to match a good choice? [/quote They're not made in China but don't let that stop you from hating on them. Have you ever ridden on a set? Link to comment
Yeeha! Stephen Posted August 29, 2012 Share Posted August 29, 2012 I too have been one of the Shinko faithful, running through 5 or 6 sets of the Ravens' already. But... I had one fail this summer and leave me stranded in Big Bend Texas. I still had a brand new set at home, and I've been running them on local rides all summer. Now that fall season is here and the rides will become longer, that creepy feeling in my gut has chased me to PR-3's for the time being. May come back, but only time will tell. Read about it in our club newsletter titled "Kindness of Strangers" http://bmwdfw.org/wp-content/uploads/2012/04/1204.pdf Down the road boys! Link to comment
Rob L Posted August 29, 2012 Share Posted August 29, 2012 I'm on my second set of Shinkos. Great tires. I bought from Rocky Mountain ATV. Best price delivered to my door in 3 days. Link to comment
jfremder Posted October 4, 2012 Share Posted October 4, 2012 After three sets of Shinko Ravens, I'm done. These dimples and several bubbles appeared on the front tire after about 6k miles. Made for a bit of a scary ride home. After sending these pics,and further evidence I had destroyed the tire, Motorcycle Superstore refunded 100% of the purchase price. Good on them, but ruining a weekend ride by discovering this 200+ miles from home made for a less than relaxing return trip. Link to comment
Polo Posted October 4, 2012 Share Posted October 4, 2012 Polo my friend: "Though there are many paths At the foot of the mountain, All those who reach the top See the same moon." All good natured ribbing. Terry I had not visited this thread since I posted, but yes Terry, all in good fun. Link to comment
Mike Kane Posted October 7, 2012 Share Posted October 7, 2012 Just picked up a set of Dunlop Roadsmart 2s for my 2007 R1200RT for $275.00 with free shipping from Competition Accessories. Mike Kane Link to comment
cgs500 Posted October 8, 2012 Share Posted October 8, 2012 On my return from Denver after buying a bike to replace my totaled 03 R1150RT, I stopped in Goodland, KS. I was hoping to fnd some gloves to replace the ones I had. I found and guy (Bobby) on a Honda Aspencade with a bald rear tire. He had no luck at the shop we were at so he decided to limp to Denver where he would have more options. He only had 1500 miles on his Shinko. I hope he made it to Denver then onto Utah. He was headed out for some National Guard training and was loaded down but he was riding solo. I can't believe his ruck and saddle bags would have weighted more than 250 lbs. Link to comment
