Scarecrow Posted September 18, 2012 Share Posted September 18, 2012 My throttlemeister no longer 'holds'. If I turn on the grip warmer, it will, but cold - nope. I am sure there is some simple adjustment I can do, but I have no clue how. I've taken off the silver end thingee thinking there would be something obvious under it. It may be obvious to someone else but not me. This is what I see when I take it off: I have no clue what I'm looking at. Can someone enlighten me? Do I need to take off the whole grip? And if so, how do I do that? Any help would be appreciagted. I thought I could wait for a tech daze to roll around, but would like to make it happen sooner if I can. TIA, Link to comment
Danny caddyshack Noonan Posted September 18, 2012 Share Posted September 18, 2012 Loosen the grip/throttle assembly and slide it to the right just a hair. Maybe two. You shouldn't need much. It works with warm grips due to expansion. That's why you don't need much adjustment. Link to comment
DiggerJim Posted September 18, 2012 Share Posted September 18, 2012 Here's a link to their instructions. Link to comment
algover Posted September 18, 2012 Share Posted September 18, 2012 "Ask and ye shall receive." This site is amazing! Link to comment
Peter Parts Posted September 18, 2012 Share Posted September 18, 2012 The last thing you want to add to your throttle hand is friction. Duh. Use a throttle counter-force spring instead. Ben Link to comment
Selden Posted September 18, 2012 Share Posted September 18, 2012 I did mine yesterday, so it's fresh in my mind. The switchgear in your photo looks like it's an oilhead. 1. Remove the small phillips screw on the lower backside of the switch assembly, and pull back the switch cover 2. Loosen the allen screw that clamps the brake lever/throttle 3. assembly to the handlebar 4. Turn the Throttlemeister ~1/4 turn (this should move the throttle assembly in slightly) 5. Tighten the allen screw 6. Check Throttlemeister Repeat steps 22-6 until you are satisfied with the result. Link to comment
Quinn Posted September 18, 2012 Share Posted September 18, 2012 I used a couple or three business cards as a a feeler guage/spacer to set the gap once the brake lever assembly is loosened. If it's too tight when the grip heater is warmed up and giving you a sticky throttle, add a small washer that will fit flush inside the throttlemeister to give it a little extra space. ------ Link to comment
Scarecrow Posted September 18, 2012 Author Share Posted September 18, 2012 Here's a link to their instructions. I did mine yesterday, so it's fresh in my mind. The switchgear in your photo looks like it's an oilhead. 1. Remove the small phillips screw on the lower backside of the switch assembly, and pull back the switch cover 2. Loosen the allen screw that clamps the brake lever/throttle 3. assembly to the handlebar 4. Turn the Throttlemeister ~1/4 turn (this should move the throttle assembly in slightly) 5. Tighten the allen screw 6. Check Throttlemeister Repeat steps 2-6 until you are satisfied with the result. Thank you all for the responses. (Algover - yes this site is truly amazing) Thanks for the link to the instructions from DiggerJim and for the step by step by Selden. Much appreciated. Now I just have to get all 10 of my thumbs coordinated enough to do it. Link to comment
Selden Posted September 19, 2012 Share Posted September 19, 2012 Thank you all for the responses. (Algover - yes this site is truly amazing) Thanks for the link to the instructions from DiggerJim and for the step by step by Selden. Much appreciated. Now I just have to get all 10 of my thumbs coordinated enough to do it. Seriously, it's a 5-minute job, requiring less skill than changing the spark plugs. The trick is to find the "just right" gap, small enough that you can still engage the TM when cold, but large enough that it doesn't bind when the grip heaters are on high. If you don't get it right on the first try, very little effort to adjust it again. Link to comment
Scarecrow Posted September 19, 2012 Author Share Posted September 19, 2012 FAILURE!! When I say I am all thumbs, I mean it. I couldn't even do what should be a 5 minute job. I found 2 small philips screws under the switch assembly. I got those out (only after dropping each one and luckily finding them on the floor) but then couldn't see the next step (allen screw). grrrrr. So I decided rather than really push my luck, I would just put the plate back on with the 2 screws. but nooooooooooo! Not I. I managed to drop the small black screw somewhere inside the bike. Actually I dropped it about 4 times, managing to find it on 3 of those. The 4th one -- nope. Have no idea where inside the engine the thing is. This is why I like to do these things at a Tech Daze; so I have someone around to help bail me out. F*ck me! Thanks for all the suggestions, but I'm just hopeless. If I only had a brain (and coordination). . . Link to comment
Selden Posted September 20, 2012 Share Posted September 20, 2012 Sorry to hear that. There must be many other BMW owners in the bay area, at least some of whom have Throttle Meisters. Link to comment
Mister Tee Posted September 24, 2012 Share Posted September 24, 2012 I have a Throttlemeister myself, but not on an RT. I have it on my C14 with heated grips. Maybe the BMW application is different but with most of the bike installs there is a hard plastic sleeve that slides under the rubber grip and over the bar, and provides a solid friction contact point for the Throttlemeister bar end. I omitted that initially, bad mistake - installed it and it works fine. Still not as good as a real cruise control though. Link to comment
