janpat3839 Posted November 6, 2012 Share Posted November 6, 2012 Recently bought a top case but need to change lock. bike in question is a "03" 1150 RT top case is a 22ltr I have a lock to put back in once I get other removed, but help how to removed when I don't have key!!! Link to comment
Aussiegazza Posted November 6, 2012 Share Posted November 6, 2012 I have just done a new lock on a new topcase. The key must be inserted and the locked turned to extract it. A pin is then inserted into the side of the lock (on the inside of the case) to extract it. I would think you will need to drill the old lock out. Do not go too deep or too wide. The new lock should guide you. You need to essentially drill the pawls into 2 pieces (or enough for them to be pulled out with pliers. The last (deepest) pawl holds the lock in. When you can rotate the lock, insert a probe to press it down and remove the lock. Garry Link to comment
janpat3839 Posted November 6, 2012 Author Share Posted November 6, 2012 thx it seems that there is another way that doesn't include drilling, I'm hoping someone can direct me to that effort... Link to comment
Aussiegazza Posted November 6, 2012 Share Posted November 6, 2012 This is the manual's instructions on drilling out the fuel cap lock. I think it would be similar for the pannier" Drilling out lock barrel e Attention: Note drilling depth. Make sure that metal chips do not drop into the fuel tank. • Use a 4-5 mm (0.1574-0.1968 in) dia. drill bit to drill the full length of the lock barrel. • Continue to increase the diameter of the drill bit until the lock barrel can be extracted. The same instructions are given for the ignition lock. If there is an easier way to extract lock barrel that does not require the key, then I too would love to know it. Garry Link to comment
Quinn Posted November 6, 2012 Share Posted November 6, 2012 you might call a dealer and see if they have a selection of old keys and see if one of them fits. ----- Link to comment
janpat3839 Posted November 6, 2012 Author Share Posted November 6, 2012 thank you to all who contributed to this thread, I did end up going to Dealer for $50 (they picked lock). To replace entire lock because orange tang was broke off, $160 replacement cost is difficult to cough up... Link to comment
janpat3839 Posted November 11, 2012 Author Share Posted November 11, 2012 is it true that top case lock and side case locks are the same. because if I replace complete assemblies because tang is broke Realoem.com has parts but doesn't differentiate between top case and side case Link to comment
Aussiegazza Posted November 11, 2012 Share Posted November 11, 2012 They are the same. Link to comment
janpat3839 Posted November 16, 2012 Author Share Posted November 16, 2012 Thank you it helps because the cost involved is huge...it saves a lot, because realm.com has a great deal. Link to comment
janpat3839 Posted November 16, 2012 Author Share Posted November 16, 2012 sorry realoem.com Link to comment
