w2ge Posted December 1, 2012 Share Posted December 1, 2012 I was looking at a roll of my son's HOCKEY tape (stuff that you get for a couple bucks a roll at any hockey rink, etc and in multiple colors if you want) and started thinking, "BOY, this sure looks like BMW loom wiring tape.." Curiosity gets me, I google the specs on CERTOPLAST 514 (BMW spec tape) and it is: "High quality polyester fabric tape with especially smooth polished surface, in combination with a strong, rubber-based adhesive." pretty much exactly the same specs when I googled 3M hockey tape. Not saying it is exactly the same, but....??? Link to comment
dirtrider Posted December 1, 2012 Share Posted December 1, 2012 Evening Phil A couple of things your need to verify. The temperature flash point of the tape & the melting & flash point of the adhesive. I have seen a few car fires caused from using improper loom tape that the adhesive melted at a fairly low temperature & dripped on a hot engine or exhaust part & caused the fire. Link to comment
hopz Posted December 2, 2012 Share Posted December 2, 2012 Are either of these related to the old-fashioned "friction" tape... in either a good or bad way? Link to comment
Guest Kakugo Posted December 2, 2012 Share Posted December 2, 2012 Certoplast 514 is made according to BMW spec GS95008-3 flame resistant standards which are a tad over most commercially available insulating tapes. To cut a long story short it has to resist 3000 hours at 125°C and be able to withstand a temperature of 150°C short term. Can hockey tape do the same? A 25 meter roll of Certoplast tape can be had on eBay for about $12 plus shipping. Curiously enough the 514 seems to be quite rare but you can get the 523 (higher specs) quite easily. Link to comment
w2ge Posted December 3, 2012 Author Share Posted December 3, 2012 D*mn... I think the wife is gonna be p*ssed when I stick the roll of tape in the oven for 3000! hours at 250 F. to test it! (well, it is ONLY 125 days...) I'm thinking if your in a bind and NOT in a critical area (that is not in an "engine bay", not by a heat area...) it would work for you. Link to comment
