Exploreinman Posted December 23, 2012 Share Posted December 23, 2012 Anyone have experience with these: http://www.bmwmotorcycleaccessories.com/BMW-R1200RT-Driving-Light-Kit-Martin-Fabrication-MFAB-L1050H3-R12RT.htm If so, what's your opinion? Link to comment
id09542 Posted December 23, 2012 Share Posted December 23, 2012 The price looks decent. May want to ask them a few questions: What are the install instructions, wonder how the connections are made for power. Also be a little concerned on how water tight the housing is, down low they will get dirty and wet. Can you purchase replacement lenses when a rock cracks one? If you order, post back how it went. Link to comment
MikeB60 Posted December 23, 2012 Share Posted December 23, 2012 I had a set. Good for being seen, not so much for any added vision to the front. No issues with the wiring harness, which included a relay, and the mounts for the lights. The lights themselves are cheap and I had rust/corrosion issues with both lights. Took them apart, cleaned them up and coated with di-electric grease. Promptly hit a dog and took out the left light so cant say how the fix worked. Replaced with some LEDs on the crash bars which are much better for vision to the front. Link to comment
