RAMBLIN RED Posted January 28, 2013 Share Posted January 28, 2013 When the charger is plugged in(to the wall) I get a green "charged" light before I plug it to the battery. My volt meter isn't sensitive enough to read exact voltage but output is between 13 and 14 volts( battery end unplugged) I inherited this thing with the bike and don't know it's age but I'm thinking I need a new one.....any thoughts? Link to comment
terryofperry Posted January 28, 2013 Share Posted January 28, 2013 Do you have the owner's manual? If not, try these. It looks as though you should hook up the battery and then plug in the A/C but that may not matter. http://www.batterychargers.com/Documents/0099001192WB-00.pdf http://www.batterychargers.com/ManualSearch.aspx?Keywords=SEM-1562A Terry Link to comment
ratfink Posted January 28, 2013 Share Posted January 28, 2013 When the charger is plugged in(to the wall) I get a green "charged" light before I plug it to the battery. My volt meter isn't sensitive enough to read exact voltage but output is between 13 and 14 volts( battery end unplugged) I inherited this thing with the bike and don't know it's age but I'm thinking I need a new one.....any thoughts? It's difficult to test a float charger with a voltmeter because the charger depends on feed back from a battery to determine the state of charge and regulate its output. I have had three schumaker "smart chargers" over the years and two of them were nothing but trouble and their support is atrocious. I've had a battery tender junior that has funcioned flawlessly for about seven years now. Link to comment
RAMBLIN RED Posted January 28, 2013 Author Share Posted January 28, 2013 Terry, plug in sequence doesn't seem to matter ratfink, I'm leaning your way think I'll buy a new one Link to comment
