Don_Eilenberger Posted February 26, 2013 Share Posted February 26, 2013 There is a recent update to the Garmin 660/665 system software. While there are a number of small fixes mentioned, the really great one is - they finally fixed the problem with accessing MP3 audio files on a mini-SD memory card. This has been an ongoing issue with these two GPS's since they were initially released. As far as I can see on mine - there is no longer any problem. The system reliably connects to the SD card and reads it, finding the MP3 files and playing them. Huzzah! The 660 Software is version 4.80. The 665 Software is version 2.80. Both are dated January 30th, 2013. I use the "Lifetime Updater" to update my systems (mostly because it makes it easy to save and update local maps used by the computer software without having to DL them for multiple devices.) You can also use the Garmin "WebUpdater" software (which is newer then Lifetime Updater.) These can be found on the Garmin website. Link to comment
Alfred02 Posted February 26, 2013 Share Posted February 26, 2013 Thanks for the head up. I just updated my 660 from version 4.70 to 4.80 Link to comment
WestyLancs Posted February 26, 2013 Share Posted February 26, 2013 That's good to know. I'm currently awaiting a lifetime update voucher for my Euromaps so this is timed just right, and just in time for this year's 'jaunts'. Link to comment
randy Posted February 27, 2013 Share Posted February 27, 2013 thanks just updated my 665. It took about 3 hours start to finish. Link to comment
Runnor Posted February 27, 2013 Share Posted February 27, 2013 Thanks for the heads up. Now, the dumb question of the day. I just bought my 660 last spring. how do I update it, and how much will it cost? I'm looking forward to this fix. Had the mp3 problem. John Link to comment
Albert Posted February 27, 2013 Share Posted February 27, 2013 That is good news Don. My 660 would fairly regularly "drop" the mp3s on the sd card. I could eventually get them back but it's been a pain. Link to comment
w2ge Posted February 27, 2013 Share Posted February 27, 2013 Thanks for the heads up. Now, the dumb question of the day. I just bought my 660 last spring. how do I update it, and how much will it cost? I'm looking forward to this fix. Had the mp3 problem. John John, DId you register your GPS on "MyGarmin".. IF not, https://my.garmin.com/mygarmin/login.htm?service=https%3A%2F%2Fmy.garmin.com%2Fmygarmin%2Fcustomers%2FmyGarminHome.faces Register your unit, then plug your unit (with the USB cord) into your PC, drivers will probably be downloaded) and then you may need to download a program form Garmin called WebUpdater", it will then find your GPS, check it's firmware, and tell you what firmware is available for you.. Follow the directions... Any Questions? I suggest you visit: ZUMOFORUMS.COM Oh,,, It's FREE to update your GPS. Link to comment
Runnor Posted February 28, 2013 Share Posted February 28, 2013 W2ge, thanks for the process. I'm so excited to do this. John Link to comment
