UberXY Posted April 25, 2013 Share Posted April 25, 2013 I need to do a small upgrade to the engine of my K12S that involves 17 single-use aluminum screws that need to be torqued to 27 inch-pounds. Anyone have a suggestion for a small 1/4" torque wrench that can do small values? I doubt I will ever use it ever again after this job and none of my buddies have one. Link to comment
elkroeger Posted April 25, 2013 Share Posted April 25, 2013 Park tool Co. has one. 0 - 60 in-lbs. Looks like it's under $50. Park is the Snap-on of bicycle tools. There are several others marketed for bicycles. REI has a few (although they seem to be higher range). btw - I've had good luck selling tools on ebay after the project. Or, maybe just take it back to the store. Say it was a gift. Link to comment
UberXY Posted April 25, 2013 Author Share Posted April 25, 2013 Thanks for the bicycle suggestion - I had not thought of that. I did deflect a little on Amazons EZ return policy... Link to comment
6speedTi Posted April 30, 2013 Share Posted April 30, 2013 Toolsdelivered.com They have three listed in 1/4 inch drive. Made in the USA by CDI a subsidiary of Snap On Tools. I have two of them. They come with a calibration certificate. FREE Shipping. Price is good considering you are getting a calibrated tool. I highly recommend them. http://www.toolsdelivered.com/Micrometer-Adjustable-Wrenches_c_2934-1-1.html Link to comment
Guest Kakugo Posted April 30, 2013 Share Posted April 30, 2013 Suggestion: get a Gedore Torcofix-K 4549. It has 1-50Nm settings (your measurements are equivalent to 3Nm so within range). It has interchangeable 1/4" and 3/8" heads and given the range you'll be able to use it for a wide range of applications (brake calipers etc). No point buying a cheap tool and no point buy a tool you'll probably use only once. Link to comment
