kltk165 Posted May 13, 2013 Share Posted May 13, 2013 Wasn't too comfortable with the amount of movement in the 49 liter topbox mounting mechanism. Came across this plate from Cymarc. Install was pretty straightforward, provides much more stable platform for the mounting of the topbox and is more solidly mounted. I received M6x30mm and M6x50mm mounting bolts. Not so sure why different sizes are used, however, I will be replacing all 4 mounting bolts with M6x35mm bolts. The fronts are unnecessarily long, the rear aren't quite long enough. Here are links to a before and after video I did of the rack. So far I'm pretty happy with it. Link to comment
