BOOCH Posted May 14, 2013 Share Posted May 14, 2013 To those of you that have them,can I get your opinion on which is better the 1100X Platinum or the 1100LED lights. Thanks in advance. I have a 2005 R1200RT Steve Link to comment
Twinsig Posted January 29, 2014 Share Posted January 29, 2014 I know this is old, but which one did you go with? I have the 1100x and considering removal and install Denali D2 LED for better long range. Link to comment
BOOCH Posted February 3, 2014 Author Share Posted February 3, 2014 I haven't bought either..I guess I will wait and see what others are recommending. Steve Link to comment
Heck Posted February 3, 2014 Share Posted February 3, 2014 1100LED 1100x lights have a widely variable bulb usage life and are quite expensive to replace the bulbs.. Link to comment
RTinNC Posted February 4, 2014 Share Posted February 4, 2014 In today's world LED's seem to the the way to go! Just added Denali 2's to my GSA and like them alot! Link to comment
Dundee387 Posted February 4, 2014 Share Posted February 4, 2014 Clearwater lights are on my RT. Quality LED product. I'm not a PiAA fan. Link to comment
Bruce H Posted February 7, 2014 Share Posted February 7, 2014 I have a set of 1100X LED's on my 1150R. Hopefully these will last a bit longer than the old 1100X'S. They do command your seeing me in the daytime. I also have a set of Feugo HID'S on my GSA, these I can't run if there is other traffic but do light up the road. Link to comment
ncsonderman Posted February 10, 2014 Share Posted February 10, 2014 I've not had any bulb issues with my 1100Xs on my RT and have about 20K on them since install. They seem great and I can't believe the difference at night. I have the clearwater kristas on my GSA and they are amazing. Can't run them against oncoming traffic though due to their output. I'll be looking at another set of LEDs to supplement that have lower wattage. If I were installing accessory lights at this moment vs. 4 years ago, I'd not hesitate to go with LED. Lower battery draw, longer life, and higher output. Win, Win, Win. Price - Lose. That's 3-1 for those who are counting Link to comment
outpost22 Posted February 13, 2014 Share Posted February 13, 2014 Have had the 1100x for about 8 years. I buy standard halogen 2 pin replacement bulbs for about $4-5. If you take the stock burned out bulb, you can carefully pry off the stock lens and reseal it to a new bulb. There is no way I would pay for Piaa replacement bulbs. The trick on buying the 2 pin halogens is picking the wattage and pattern. I.e. "50 watt narrow spot" as an example. you can test beam patterns until you find what you like before affixing the old lens to the new bulb. That being said I think LED is the way to go. Less wattage, less amperage and longer life. Link to comment
Tri750 Posted February 19, 2014 Share Posted February 19, 2014 I sold PIAA lights for years when they were the latest thing. Note that unless things have changed, bulbs have a 1 yr. warranty When LED's came out, specifically Clearwater, I never sold another set of PIAA's. Magically, PIAA came out with LED after they realized that someone was eating their lunch. Clearwater's are shockingly good. When you break the price down of a set of PIAA with light bar and wiring, and compare to Clearwater, the price is very close, and many times CW is less expensive with a real person to talk to when you call with a question. Link to comment
