ElevenFifty Posted June 11, 2013 Share Posted June 11, 2013 Wiring up some aux lighting - anyone know a standard part that I could get from Autozone (or other local supplier) that would fit the bill? Thanks as always DH Link to comment
dirtrider Posted June 11, 2013 Share Posted June 11, 2013 Afternoon DH Might be a lot easier to find a resistor suppressed relay (lot of auto applications on those) Or use a standard 30 amp relay with a resistor across the pull in coil terminals. Diode suppressed are usually used on a system that uses MANY MANY relays as the diodes draw less patristic power. On a single relay application I doubt the difference between a diode & resistor suppressed would even be measurable. Link to comment
