Angel Posted August 29, 2013 Share Posted August 29, 2013 Ok so here's the hardware: Zumo 550 with XM Iphone 4s Schuberth SRC system I can get the SRC connected with the Zumo but I can't hear &^%$t I can connect the phone the the Zumo but I cant hear *&^)* either. Anybody got this set up working so that you can hear ZUmo through the SRC system? please advise me Link to comment
Edgar Posted August 29, 2013 Share Posted August 29, 2013 You know it's always something! Link to comment
terryofperry Posted August 29, 2013 Share Posted August 29, 2013 Not that system. Zumo 660, Iphone 4s, SRC, works perfectly. Terry Link to comment
enfoman Posted August 29, 2013 Share Posted August 29, 2013 You can always forgo the BT and plug directly into the SRC. Will save battery power on both units too. Not really a hands free way but it should work. Is the volume control turned up on the SRC? Top button is to lower volume. Try to re pair the units again. Link to comment
Danny caddyshack Noonan Posted August 29, 2013 Share Posted August 29, 2013 Sometimes the sequence of pairing makes a difference. Link to comment
Angel Posted August 30, 2013 Author Share Posted August 30, 2013 Yes Gary, Indeed it is!. Getting ready to head north. hoping to dial this crap on before I hit the road. Link to comment
Angel Posted August 30, 2013 Author Share Posted August 30, 2013 You can always forgo the BT and plug directly into the SRC. Will save battery power on both units too. Not really a hands free way but it should work. Is the volume control turned up on the SRC? Top button is to lower volume. Try to re pair the units again. I've tried to repair the units multiple times... the hardwire solution is my final option, i I cant dial this in before tomorrow as I am leaving on a 10 day adventure! thanks for the response Link to comment
Angel Posted August 30, 2013 Author Share Posted August 30, 2013 Sometimes the sequence of pairing makes a difference. Please tell me more... are you suggesting that the order in which I par the units may change the outcome? Link to comment
chrisolson Posted August 30, 2013 Share Posted August 30, 2013 Ok, silly question ... but, you did turn on bluetooth in the Zumo for the audio (instead of wired) as well as for the phone? Link to comment
Angel Posted August 30, 2013 Author Share Posted August 30, 2013 Ok, silly question ... but, you did turn on bluetooth in the Zumo for the audio (instead of wired) as well as for the phone? not sure I'm understanding your question... Link to comment
chrisolson Posted August 30, 2013 Share Posted August 30, 2013 The 550 outputs audio on either the 3.5mm jack or via mono bluetooth and it can be configured for phone = bluetooth connection and all other audio = wired connection or all bluetooth. If you previously had audio on the wired connection, you need to go into settings and change it so both phone and audio are bluetooth. page 45 - 46 ... not very clear directions but its the section under the heading "Audio - specify which types of audio to sent to Bluetooth headset" Link to comment
Deek Posted August 30, 2013 Share Posted August 30, 2013 Sometimes the sequence of pairing makes a difference. Please tell me more... are you suggesting that the order in which I par the units may change the outcome? Let me butt in......yes, the order can make a difference when you pair to your helmet. With my equipment (BMW OEM BT audio, Nav III BT GPS, Sena SMH10 BT headset), it is best to pair the phone to the GPS, then the GPS, and lastly the BMW audio system to the headset. What MIGHT be happening is your equipment, with which I am not familiar, might be fighting over the "how" to pair. With my headset, the connection to the motorcycle is A2DP, which is stereo, but the pair with the GPS is mono......I have NO idea if your gear is like that, but it's worth some research. Good luck. I went through heck and high water getting my system all paired up, but now it's working very well. I have my cheat-sheet for anyone who wants to see my checklists, but it's probably only applicable to my specific equipment....just email to deek589 AT bellSOuth DOT NET correcting the obvious errors in my email and put "Bluetooth" or something about BMW in the subject line to keep it out of my trash bin. Link to comment
