Jimmy D Posted September 1, 2013 Share Posted September 1, 2013 Would appreciate if anyone could give me some ideas on improving the stock R1200RT mirrors... (Have to lift my arms or pull them in to see out of them) Thanks Much!!! jim Link to comment
flat_twin Posted September 1, 2013 Share Posted September 1, 2013 Installing GS or KRS mirrors to the RT handlebars is one way to do it. Up thru 2009 it's fairly easy. I understand the 2010-13 RT's are harder due to the new switch gear. Link to comment
racer7 Posted September 1, 2013 Share Posted September 1, 2013 There are mirrors available for 2010 RT - you can probably see them at A&S, Sierra or some other on line dealer with a decent website. IIRC, they were pricey- a bit over $200. But many of us do this- the stock mirrors don't work at all well especially with camping gear on the bike. Link to comment
rgmanley Posted September 1, 2013 Share Posted September 1, 2013 On my 2010 RT I installed the GS mirrors from the 2010 GS. They fit perfectly and worked like a charm. I think this was the single best improvement I made to the RT. Can't understand why BMW thinks having the mirrors behind the hand grips is effective. Link to comment
DiggerJim Posted September 1, 2013 Share Posted September 1, 2013 I put a pair of these on my bar ends. Once adjusted and Loctited (blue) in place, they're outstanding and don't look out of place either. I did scrape the paint off the screw that holds the mount to the mirror back and filled the recessed screw with penetrating Loctite as I have heard folks who have had issues with the mirror coming loose from its housing. No problem over 2 yrs & 30K miles. Link to comment
na1g Posted September 2, 2013 Share Posted September 2, 2013 At some point (2010?) BMW changed the clamp that holds the brake and clutch levers to the handlebars, and they are no longer drilled and tapped for the GS, or other mirror stems. But you can get the parts needed to replace them and install the mirrors. As mentioned above, look on the websites of Bobs, MaxBMW, etc. I got the whole set-up (mirrors, adapters, rubber boots, replacement clamps) from Max. Not cheap, but the "lollipop" mirrors are a big improvement. I can see what's behind and have set the original mirrors to show what's beside me on the highway. Lots to look at. Not nuts for the appearance of the lollipops but 'form follows function", I guess. BTW, personally I don't like bar-end mirrors. They are too far from normal line-of-sight. I considered the SAENG clamp-on spot mirrors, too, but like the results of my GS mirrors. pete 2011 RT Link to comment
Firenailer Posted September 2, 2013 Share Posted September 2, 2013 +1 I got the whole set up from Max. You can find it all on the parts Fische on their website. Just change the top clamps on the switch gear and screw in the mirror stems. Makes a world of difference, I just couldn't get used to the stock set up no matter how I adjusted the mirrors. The above bar set up is a big improvement! Link to comment
JoePhoenix Posted September 2, 2013 Share Posted September 2, 2013 Wunderlich america sells the clamp replacements designed to hold a standard mirror. and has a couple add on mirrors to choose from. Link to comment
lkchris Posted September 2, 2013 Share Posted September 2, 2013 Can't understand why BMW thinks having the mirrors behind the hand grips is effective. I rode an R100RS for 28 years. R1200RT mirrors are the best I've ever had. Link to comment
Jimmy D Posted September 3, 2013 Author Share Posted September 3, 2013 Thanks.. i was thinking of doing the same but didn't know how well it would work.. Link to comment
RoyTemple Posted September 4, 2013 Share Posted September 4, 2013 This is my answer Link Don't know if it will work with the newest bikes or where to get the mirrors now. Roy Link to comment
Jimmy D Posted September 5, 2013 Author Share Posted September 5, 2013 Roy Thanks for the post! I like what i see.. That's perfect! I will try and see if thats going to with with mine as well.. Thanks again! Link to comment
rfetested Posted September 12, 2013 Share Posted September 12, 2013 Anything is an improvement Link to comment
Scottmac Posted September 12, 2013 Share Posted September 12, 2013 I fitted a pair of Wunderlich mirrors to my '06 R12RT. Finally, a clear view behind me, even two-up and fully loaded. Make sure you use a threadlocker, as the $10 nuts can loosen and fall off. You will need to file off a small amount of metal from inside the left mirror mounting hole, but be gentle as not much needs to be removed. http://www.wunderlichamerica.com/motorcycle/R1200RT/8410053.html Link to comment
