Torontonian Posted September 4, 2013 Share Posted September 4, 2013 I have in my hand a new Ohlins for an r1150 that is printed 01092-15/62 L285. Got it from McBrides receivership sale taking the chance that it would work/fit on my 1996 R1100RT. Best info I can find says BM 601 46ER1 is for my R1100RT. Any help would be appreciated as it looks similar. Can't be returned,thanks in advance,Peter. Link to comment
flat_twin Posted September 4, 2013 Share Posted September 4, 2013 I think the front shock is the same for both models. The rear shocks are different. BMW changed the bottom U shaped mount on the R1150RT rear shock. Your RT http://www.ohlinsusa.com/fitment&make=BMW&model=R%201100%20RT&year=1996 R1150RT http://www.ohlinsusa.com/fitment&make=BMW&model=R%201150%20RT&year=2003 Link to comment
Torontonian Posted September 5, 2013 Author Share Posted September 5, 2013 Thanks Mark, I'll try the fit ,numbers are different but will strip it down tomorrow to fit ,seems an easy enough operation ,thanks, Peter. Link to comment
flat_twin Posted September 5, 2013 Share Posted September 5, 2013 Here's pic I found of the R1150RT rear shock, lower mounting. It's not at all like the R1100RT/RS Link to comment
Torontonian Posted September 5, 2013 Author Share Posted September 5, 2013 Thanks Mark for the pic. of rear shock. Yes very different. Am concentrating on the front Ohlins repacement fit and if good will fit a rear next season. As far as I can tell the 1100 and 1150 Ohlins are the same shock only fitted with different springs so feel confident now to try it on my 96 R1100RT. Peter. Link to comment
bmwnomad Posted September 6, 2013 Share Posted September 6, 2013 Are you sure it's a 01092? The front spring should be a 01096 on both the R1100RT and R1150RT. The 01096 is 190mm long (uncompressed) and the 01092 is 170mm. If it is a 01092 its probably a lowered shock. Steve Link to comment
Torontonian Posted September 28, 2013 Author Share Posted September 28, 2013 Installed it on front and yes it is shorter than stockby about 1/4 inch so will make a steel spacer to get bike back up to proper height. Rides good though. More labour. Link to comment
Torontonian Posted October 29, 2013 Author Share Posted October 29, 2013 Fitted 1/4 inch steel spacer at top,seems good. Can't notice much difference from stock ,I suspect all the hype is because the stock Showa was so wornout (to others commenting). Link to comment
