Aussiegazza Posted September 17, 2013 Share Posted September 17, 2013 2003 R1150RT. Any easy fixes other than totally replacing the hinge (as offered by BMW)? If not, I will work out a cheap and hopefully easy fix. Currently have bent wire through it. Garry Link to comment
biometrics Posted September 17, 2013 Share Posted September 17, 2013 Why not just buy a pin the right size from a metal supplier? What size is the original pin? This should be a simple purchase from McMaster-Carr, or similar place. Link to comment
DiggerJim Posted September 17, 2013 Share Posted September 17, 2013 If you can't find a pin, check out finishing nails and when you find one, cut it to length and then just peen the end after you slide it into the hinge. Link to comment
johnlt Posted September 17, 2013 Share Posted September 17, 2013 also there are various sizes of piano wire at local hobby shops. Link to comment
bikebits Posted September 17, 2013 Share Posted September 17, 2013 The hardware aisle at Lowe's has a great selection of all sorts of small bits and pieces. I would check there first. Link to comment
Aussiegazza Posted September 18, 2013 Author Share Posted September 18, 2013 All good ideas. I will show my fix when I get it done. Garry Link to comment
Aussiegazza Posted September 19, 2013 Author Share Posted September 19, 2013 Got some 4.5mm galvanised nails that are a very good fit. Plan to drill and peen the end. Maybe turn down the head a bit. Garry Link to comment
Aussiegazza Posted September 20, 2013 Author Share Posted September 20, 2013 Turned down the head of the nail a bit (for better looks), cut a bit overlength, drilled the end a bit and used a 'press stud' tool (made for a similar purpose in joining press stud halves to clothing etc) to expand the end a bit. Worked beautifully. Garry Link to comment
bikebits Posted September 20, 2013 Share Posted September 20, 2013 Well done. There's always a bit of satisfaction in a good home-brewed fix. Link to comment
