macx Posted October 18, 2013 Share Posted October 18, 2013 Is it correct that the center post in the BMW type plug is the "hot wire"? I got a heated jacket but have to change plugs to the BMW type. Just want to make absolutely sure. Thanks! Link to comment
DiggerJim Posted October 18, 2013 Share Posted October 18, 2013 Handy rule of thumb is that the exposed powered side of connectors is usually the negative with the positive shielded in some way. That prevents accidental shorts. So the bike side the positive is deep inside and the accessory side (which is unpowered when the plug is exposed) would have the positive as the center pin. Which is a good thing to think about when you add wiring yourself - like an SAE plug connector where the bike/battery side should have the positive from the battery wired to the shielded side and the bare pin is the negative since you'll often have the connector exposed. Link to comment
macx Posted October 18, 2013 Author Share Posted October 18, 2013 Thx. That's the way I've always known it to be over 40+ yrs of hot rodding and lots of hands on with all types of vehicles & equipment. Reason I asked is that this morning I plugged in a new piece of heated clothing on which I had to install a BMW type plug in place of the typical US lighter type plug. When I first turned it on, something in the control apparently shorted out and burned thru a couple layers of clothing. The vendor is being real good about exchanging it. Just wanted to rule out any small chance I may have unwittinglly done something wrong. Link to comment
drtnsnw Posted November 6, 2013 Share Posted November 6, 2013 I just found out this is wrong when I blew the fuse on my GPS. The BMW is grounded through the center pin and the hot is the outer connector. I have a couple of cigarette lighter styles on mine and every one is backwards. Chris Link to comment
lkchris Posted November 6, 2013 Share Posted November 6, 2013 The BMW standard (DIN standard of course) for its power plugs is center is positive. They can be incorrectly connected with a little effort. Were this not the case I'd have ruined my BMW battery charger years ago. Link to comment
drtnsnw Posted November 7, 2013 Share Posted November 7, 2013 I guess I better figure out what the heck is going on with my power feed. It seemed kinda crazy to me but every one of mine is hot on the outside and ground on pin Chris Link to comment
drtnsnw Posted November 7, 2013 Share Posted November 7, 2013 Well after IKchris set me straight I went out and pulled the fairing off. I found a factory pigtail from what looks like maybe the radio harness going to the power outlet on the dash was cross wired and it really looks like it came that way from the factory. I checked it 3 ways to Sunday and one of the plugs is backward which threw all the other ties wrong!! Chris Link to comment
kgerry Posted November 8, 2013 Share Posted November 8, 2013 when in doubt grab a DMM and meter the plug... easy to check polarity right at the plug Link to comment
kgerry Posted November 9, 2013 Share Posted November 9, 2013 i just metered my 2013 RT and center pin is hot (12V) and outer jacket is ground... Link to comment
