doc47 Posted October 27, 2013 Share Posted October 27, 2013 I need some advice with a relatively simple wiring project. I've got a set of Hella LED off-road lights on my Dakar. Each one has a black and a white wire. I want to operate them with a standard waterproof PIAA push-button switch. The switch has an indicator light and so it has three wires: white, black, and red. There is a relay in the circuit, the standard one that came with the lights. Would someone advise me on how to connect all this? Waiting breathlessly, Yours, Electrically Challenged Link to comment
Gregori Posted October 27, 2013 Share Posted October 27, 2013 If you're not careful, they'll ALL turn into black wires... The lights (and relay, and switch) should have a schematic diagram, explaining the right way way to wire them. Sadly, while there is supposed to be a standard to the wire colors, not every manufacturer follows it. (DAMHIK) If it's all very confusing from the drawing, I can't imagine how a description on this board will clarify it for you! Find someone local (Tech Daze?) to give you a hand. It's not difficult, but a continuity tester (and multi-meter) in the right hands will make it go even smoother. Good luck! Link to comment
doc47 Posted October 27, 2013 Author Share Posted October 27, 2013 Thanks, Greg. I nearly had a bike (Marlene Dietrich) that ended up like that. Entire wiring harness fried and nearly did a Dresden on me. The problem is that the lights are Hella and don't have neat little plug-in ends and the switch is PIAA....and does. I'm also just a bit wary of how to incorporate the relay. Link to comment
doc47 Posted October 27, 2013 Author Share Posted October 27, 2013 And I'm in the Mississippi Delta! We don't got no steenking tech days! Link to comment
mnTwin Posted October 27, 2013 Share Posted October 27, 2013 Hi Doc, Check out the diagram at this link. It should help you get started. If you have more questions, just ask. Just scroll down a little on this page: http://www.polarisatvforums.com/forums/atv-new-members/21624-piaa-relay-switch.html Link to comment
doc47 Posted October 27, 2013 Author Share Posted October 27, 2013 Exactly what I needed! God, I love this forum! Thanks!!! Link to comment
doc47 Posted October 28, 2013 Author Share Posted October 28, 2013 I still love the forum but the lights ain't workin'. And I'm puzzled. The lights work if I hook them up directly, so that's not the problem. Could it be that white isn't ground (earth) on the switch, whereas it is on the lights? Or could it be the relay? The LED indicator light on the switch normally turns green when the lights are off, and red when they are on. The red wire coming from the switch powers that indicator light. What makes the light turn from red to green? What price glory? Quo vadis? Which was more, Grant or Lee? Link to comment
mnTwin Posted October 28, 2013 Share Posted October 28, 2013 I still love the forum but the lights ain't workin'. And I'm puzzled. The lights work if I hook them up directly, so that's not the problem. Could it be that white isn't ground (earth) on the switch, whereas it is on the lights? Or could it be the relay? The LED indicator light on the switch normally turns green when the lights are off, and red when they are on. The red wire coming from the switch powers that indicator light. What makes the light turn from red to green? What price glory? Quo vadis? Which was more, Grant or Lee? Doc, Sounds like it's not connected quite right. Is there a part number, or diagram on the relay? If not, could you take a picture of the relay? Is the LED on the switch working? >>What makes the light turn from red to green? There is an extra circuit in the switch (powered from the red wire) that controls the LED to make it change color. Pictures of the relay and or part numbers would be helpful. Link to comment
Chris K Posted October 28, 2013 Share Posted October 28, 2013 Hey doc. Here is a link to a set of PIAA instructions using the switch you have: http://www.piaa.com/Shared/instructions/2000%20Series.pdf It looks like the white wire is used to bring power from the battery and the other two wires go to the relay. Ride it up here and I'll get it working for you! Link to comment
Marty Hill Posted October 28, 2013 Share Posted October 28, 2013 Doc, I did the same thing 6 years ago. Piaa switch to hella lights. Can't remember what I did cuz my memory sucks. I do remember having a problem with the wires. If needed I'll ride over to Chris K's and I'm sure he can figure it out in a minute or so. Link to comment
Bud Posted October 28, 2013 Share Posted October 28, 2013 The only thing I know for sure is that if the "magic smoke" escapes from the wires, everything stops working. Link to comment
GRB60 Posted October 28, 2013 Share Posted October 28, 2013 Where there are whit, black and red I would suggest that red is the positive, black the negative and the white is the constant (low voltage) hot for the light on the switch only. So, switch red and white and try again. Keep fire extinguisher handy. Link to comment
terryofperry Posted October 28, 2013 Share Posted October 28, 2013 Greg We are not dealing with logic here, we are dealing with factory Engineers. Just saying. Terry Link to comment
