moshe_levy Posted October 31, 2013 Share Posted October 31, 2013 Hi Guys- What's everyone using for a weatherproof case and mounting assembly for your I Phones? I'd like to put near my GPS on the RT. -MKL Link to comment
moshe_levy Posted November 1, 2013 Author Share Posted November 1, 2013 NOBODY? Can't be. C'mon...... -MKL Link to comment
Rougarou Posted November 1, 2013 Share Posted November 1, 2013 Lifeproof case with lifeproof mount. Link to comment
marc11 Posted November 1, 2013 Share Posted November 1, 2013 I have my Galaxy SIII in a UAG case mounted via a RAM Clutch Reservoir base and RAM x-mount. If it rains, I will either just cover the phone with a zip lock baggie or throw it in my glove box. BT works fine through the glove box. I used to use THIS on another bike for my iPhone and it works fine as well, but expensive. Link to comment
tallman Posted November 1, 2013 Share Posted November 1, 2013 Does Apple still support the I 5? Link to comment
Art.. Posted November 4, 2013 Share Posted November 4, 2013 Ram X mount on my Ducati. If it rains, I put the phone in my pocket. Link to comment
Scott Deakin Posted November 4, 2013 Share Posted November 4, 2013 I have the same setup mentioned above, but a different brand name in the UK: http://www.amazon.co.uk/Waterproof-suitable-mounting-Ultimate-attachments/dp/B00AQ68XRK/ref=sr_1_1?s=electronics&ie=UTF8&qid=1383558840&sr=1-1&keywords=ultimateaddons - I have been through rain so hard I cannot see the road markings properly and it's never leaked (unlike my bike gear ) I also bought the power separately (seems included in the bundle above) which worked worked well with my old iPhone 4, but on the 5 it complains about compatibility - although it still works. (http://www.amazon.co.uk/Ultimate-Motorcycle-Hardwire-Battery-Charging/dp/B00AYEUBRO/ref=sr_1_1?s=electronics&ie=UTF8&qid=1383561192&sr=1-1&keywords=ultimateaddons+iphone+power) - note be careful if you power this via the canbus switched power. I found it pulls enough current with the phone attached to stop it switching off! I ended up buying one of the power distribution boxes with a relay switch. I also use it to listen to music via an Autocom bluetooth. If you do the same, you might want to check out the CarTunes app - it lets you control music with simple full screen gestures, so you don't need to look for buttons to press - I find it only works reliably with my thumb through the gloves and screen. https://itunes.apple.com/gb/app/cartunes-music-player/id415408192 I forget which mount I bought, mostly because I butchered it to fit onto the GT satnav plastic handlebar mount. Here is what it looks like on the bike: Link to comment
John in VA Posted November 5, 2013 Share Posted November 5, 2013 I have a RAM mount mounted one of the handle bar bolts. RAM is a great system. I wired in a USB charger spliced into the left accessory socket wire, threaded up through the steering head. Works great. Link to comment
