vbr1100rt Posted November 22, 2013 Share Posted November 22, 2013 Put the dash back on, connected everything back up, and tried to set the clock. Now the hour button is stuck in slightly, and the hours are constantly incrementing. Pulled the dash back off, and can't tell if there is a way to take the display apart. Any suggestions? Link to comment
Stan Walker Posted November 22, 2013 Share Posted November 22, 2013 You can use a pin or sharp needle to lift the rubber button back to it's correct position. Stan Link to comment
vbr1100rt Posted November 22, 2013 Author Share Posted November 22, 2013 Thanks! I managed to pull the button up slightly with a dental pick, and it seems to be working properly now. I plugged it back in while the hour button was still stuck down, and every display segment was illuminated. Guess the stuck button confuses the control logic if it's powered up in that state. Hopefully the button stays unstuck when I set the clock, but if not, I'll just dig it out again with the pick. Link to comment
