Torontonian Posted November 22, 2013 Share Posted November 22, 2013 Every bump gives small clunk-sounds and noticing the 3 cases don't close down to supports as firm as before,anyone fix these ? Everything looks sealed for life. 96 r1100 rt. Link to comment
g_frey Posted November 23, 2013 Share Posted November 23, 2013 They do tend to get loose after 90,000 miles. There are various ways to tighten it up but most involve some type of adhesive. All of my noise comes from the contact area between the case and the rack that supports it. A look at the area after taking the cases off shows wear has happened. I would guess contact cement and pieces of thin inner tube (bicycle) would take up any slack OK and help quiet it down too. Link to comment
Torontonian Posted November 24, 2013 Author Share Posted November 24, 2013 Will try glue and bicycle tube pieces at those support areas. Thanks. Now I have to think about the small clunks coming from the front fairing area when hitting those bumps. This could be harder to figure out. Hall-vane replaced at 90,000 ,bike has been good so far. Synthetic oils too. Link to comment
oldyam Posted November 24, 2013 Share Posted November 24, 2013 For the clunks from the front ...... check the horn is still fastened to its bracket, Dont ask how I know ..... Lol Link to comment
Torontonian Posted November 27, 2013 Author Share Posted November 27, 2013 Will check horn but light rattle sounds like things loose in there. Link to comment
