BMWLou Posted December 16, 2013 Share Posted December 16, 2013 Made out the other day and found a BMW Top Box, like new condition, and even the BMW metallic black of my 90th Anniversary RT. My question, how do I remove the lock cylinder so I can rekey it to match the RT's ignition key. I do have the original Top Box key. Link to comment
Sailorlite Posted December 16, 2013 Share Posted December 16, 2013 I've re-keyed several cases after carefully following the procedure set forth here: http://www.ebbo.org/re_keying.php Link to comment
BMWLou Posted December 16, 2013 Author Share Posted December 16, 2013 I've re-keyed several cases after carefully following the procedure set forth here: http://www.ebbo.org/re_keying.php Worked like a charm Sailorlite. Must admit did tale a bit of probing to find the sweet spot. Link to comment
VoipWizard Posted December 16, 2013 Share Posted December 16, 2013 That sweet spot is elusive at best... Spend 4 days trying... tok me 5 seconds to remove the cylinder... Link to comment
swilson Posted August 26, 2016 Share Posted August 26, 2016 Looks like the old web site that had info on removing the lock cylinder easily is gone. I've put up a youtube video covering the lost info so its still available. Link to comment
Ron2012 Posted August 26, 2016 Share Posted August 26, 2016 This works for removing a lock set without a key: Link to comment
