RedTRex Posted December 31, 2013 Share Posted December 31, 2013 My new to me 1150rs, 28k miles. Learned about left cam chain tensioner while reading here, realized mine was still original. Ordered replacement from Rubber Chicken Racing. Took about 30 min to R&R and I am amazed how much smoother and more powerful she is..... less noise too. Link to comment
lkchris Posted December 31, 2013 Share Posted December 31, 2013 It cannot physically be "smoother and more powerful." It will be less noisy. It's a good upgrade for sure. Link to comment
4wheeldog Posted December 31, 2013 Share Posted December 31, 2013 It cannot physically be "smoother and more powerful." It will be less noisy. It's a good upgrade for sure. Actually........I had the same experience as the OP when I replaced mine years ago. I did not expect it, and had to think about it a bit to come up with the likely explanation......Which is, that with the old tensioner, the cam timing was subject to a small amount of "Float", under all circumstances. Mine runs better hot, and is not subject to the same occasional single large knock when throttle is applied to get the beast moving. There is more reason to replace the original tensioner than just the noise involved. Link to comment
danevans Posted January 1, 2014 Share Posted January 1, 2014 Are both sides normally done? I would think it would be the sensible thing to do. Link to comment
4wheeldog Posted January 1, 2014 Share Posted January 1, 2014 Are both sides normally done? I would think it would be the sensible thing to do. No, they are not. The right side does not lose its oil, so the tension is much more consistent. I did consider changing it, when the left side had so much of an effect, but all the odd behavior was gone, so there did not seem to be any reason to do it. Link to comment
RedTRex Posted January 1, 2014 Author Share Posted January 1, 2014 It cannot physically be "smoother and more powerful." It will be less noisy. It's a good upgrade for sure. Not more so than original stock configuration of course but compared to the way it was running it does feel a whole lot smoother and more powerful. .... off to mount my new Stebel horn Link to comment
longbch Posted January 3, 2014 Share Posted January 3, 2014 I experience the same thing when I replaced the left tensioner this summer on my '99 RT. The bike seemed to run smoother and shifted easier. I wasn't expecting that. I mentioned this on our club's Yahoo group, and another person said they noticed the same thing with their bike. The biggest change that I noticed this year was that the bike is running now a lot smoother since I did my own valve adjustment and sync, and not the dealer. Link to comment
mikeR1100R Posted January 3, 2014 Share Posted January 3, 2014 I don't know about smoother running but I do know that my bike no longer sounds as if the motor is coming apart when I start it after I replaced the LH cam chain tensioner. Link to comment
