Rex R Posted April 6, 2014 Share Posted April 6, 2014 What methods do you use to mount your ez pass (or similar) toll transponder? I've tried a few gadgets and different locations with various degrees of success. I just tried using the Velcro strips that EZ Pass supplies on my windshield but they peeled right off the first time I removed the tag! Any suggestions on getting them to stick? I cleaned and dried the windshield before mounting the strips. I also gave the adhesive several minutes to set. The strips still came right off with the tag. Never had the problem on the glass windshield on my cars. Link to comment
Bud Posted April 6, 2014 Share Posted April 6, 2014 I've been told that they work reliably in the top of your tank bag. That's where mine is right now but I haven't gone thru a toll plaza yet. Link to comment
RTinNC Posted April 6, 2014 Share Posted April 6, 2014 If you use anything like Velcro I would go with 3M Dual Locks. But there are a lot of options such as Ram Mount. Link to comment
walton66 Posted April 7, 2014 Share Posted April 7, 2014 I've been using mine in my tank bag since last July with no problem but yeasts I received a letter with a bill by license plate invoice. It seems that in the middle of a weekend dash north, it didn't register at a couple of stations. Registered before and after these particular plazas. They charged ne an admin fee which was more than the tolls. A phone call is on my agenda tomorrow Link to comment
Mike Posted April 7, 2014 Share Posted April 7, 2014 Tank bag has always wired for me. Another option. Link to comment
mrzoom Posted April 7, 2014 Share Posted April 7, 2014 3M dual lock vertical to lid of top case . Have forgotten it a few times and no foul but this is Illinois Link to comment
Rex R Posted April 9, 2014 Author Share Posted April 9, 2014 Thanks for the input everyone. Unfortunately, I rarely ride with a tank bag or top case. The "velcro strips" that I used were the dual lok strips that EZ Pass supplies with the tag. I have a couple of extra sets of strips on order. Hopefully, I'll have better luck applying them. In the meantime, anyone else care to volunteer how you mount your tags to your machines? Link to comment
RTinNC Posted April 9, 2014 Share Posted April 9, 2014 I have one of these that I bought used and have not mounted yet. http://www.twistedthrottle.com/toll-pass-holder-for-ez-pass-m-tag-ipass-smart-tag-toll-passes-on-motorcycles-scooters Link to comment
Oldironken Posted April 9, 2014 Share Posted April 9, 2014 Would putting it in you chest pocket work? Link to comment
Ausflug Posted April 10, 2014 Share Posted April 10, 2014 Would putting it in you chest pocket work? It should. It works inside tupperware, in the back of a commercial moving van. Don't ask me how I know... D'oh! Link to comment
Sweendog Posted April 10, 2014 Share Posted April 10, 2014 Min is mounted to the underside of the windscreen using the 3M Dual Loc strips that EZ-Pass provides. I've not had an issue with the strips coming off. I just cleaned the area well using Simple Green, then wiped with some alcohol and let it dry. Then I mounted the strips to the EZ-Pass, peeled off the paper, and stuck the pass to the screen. Link to comment
Deezalman Posted April 15, 2014 Share Posted April 15, 2014 Would putting it in you chest pocket work? I do it all the time but recommend using an exterior pocket AND if possible face the velcro side of the transponder outward. The directional antenna is located on this side of the unit. I have the original 'square' transponder. The newer units are smaller and likely have an improved antenna, making them less sensitive to positioning when presented to the receivers. Link to comment
