Malthound Posted April 19, 2014 Share Posted April 19, 2014 Anybody have any experience with one of these? http://www.turnabike.com/products/saddle/ A bit on the pricey side, but I like its small size. I'm curious if the added height makes the center stand more difficult to deploy. Link to comment
Malthound Posted April 20, 2014 Author Share Posted April 20, 2014 Actually, after a bit more digging, I found this one: http://tinyurl.com/lqpn3t3 Reading the specs, it looks like the total height of the base at the point of contact for the center stand is about 7/8" (less if I remove the rubber mat). I just put a 1" thick piece of scrap wood under my center stand and I was JUST barely able to get it fully up and locked. I like the locking casters on this one, and it's cheaper. Looks like a winner to me. Link to comment
GrayNFast Posted April 20, 2014 Share Posted April 20, 2014 I have the one from Legal Speeding; looks like the same set up and works great. Dean Link to comment
szurszewski Posted April 20, 2014 Share Posted April 20, 2014 I made one out of a "surplus" plastic cutting board and a lazy Susan type turntable from an old monitor stand (has cylindrical roller bearings in it). Works well but the cutting board is not non-slip, so I have to be careful when "spinning." Less than an inch total height, and it does make it harder to get the bike on the center stand, but not nearly as much harder as it gets with a 2x4 under the stand. josh Link to comment
Tri750 Posted April 20, 2014 Share Posted April 20, 2014 A friend of mine had one in his garage last time I was there. It was a Telefix. A good brand. He no longer has the bike. He said he wanted 150 for it. Likely used just a few times if I know him. PM me if you want me to check on it. Located in Fresno Link to comment
SteveHebert Posted April 21, 2014 Share Posted April 21, 2014 I paid $199 for mine. Can't remember the brand name but they all look identical. Best thing I have bought as an off bike accessory. It is well worth the $$. Link to comment
Bud Posted April 21, 2014 Share Posted April 21, 2014 Used one for sale on the MOA flea market for $130 Link to comment
louisvillebob Posted April 23, 2014 Share Posted April 23, 2014 I've used something similar from Wunderlich for years. It's quite handy for moving or turning the bike around in tight spaces. Recommend it. Use it for R100RTs (about 500#). Have not tried it for heavier bikes. There's a technique to getting the bike on the saddle, but it's not difficult. Not much different than using the center stand on concrete floor. Same cautions apply. Bob Link to comment
Kritou Posted April 23, 2014 Share Posted April 23, 2014 If, as the OP's title suggests, the object is just to tun the bike as opposed to moving it then one solution is a turning plate I made mine of two circular pieces of polyethylene about 38cms in diameter. Put a small nut and bolt through the middle and you are done The two pieces I used are 6 and 2mm thick so lifting the bike onto it's centrestand is a non issue I have another version where the materials are a total thickness of 4mm and this turntable is flexible enough to fit in a pannier when touring If I could figure how to get a photo from my iPad into a post I would do so! Link to comment
