Perk1975 Posted May 19, 2014 Share Posted May 19, 2014 in 2005 I thought the stock radio was a good idea..... Now I am not convinced, I would like it much more if it had an external input to it. The only way I can do it now is to use an FM transmiter. Has anyone come up with a good work around for this? Link to comment
RT_Jim Posted May 21, 2014 Share Posted May 21, 2014 Perk - Can you explain in a little more detail what you're trying to do? I have a 2012 RT and I 'turned off' the built in speakers and instead, wired in a lead so I could have the sound come to my helmet. Also, the radio has an external adaptor for USB or an iPod type device, if that's what you're looking for. Jim Link to comment
Perk1975 Posted May 21, 2014 Author Share Posted May 21, 2014 I didn't know the radio has an external adaptor for USB/ipod device. How do you get at that? If it truly is that simply I will be happy, but feel like a bit a fool. Nothing new! My goal is to be able to play an external source through the existing speakers. Link to comment
lkchris Posted May 21, 2014 Share Posted May 21, 2014 Do you have the owners manual for the radio? If not your dealer can get you one. Link to comment
marcopolo Posted May 21, 2014 Share Posted May 21, 2014 I have an '06 RT with the "radio". It comes with a CD player. There's no other input source that I'm aware of. Link to comment
Perk1975 Posted May 21, 2014 Author Share Posted May 21, 2014 So I found the owners manual on line for the 2007 version of the radio owners manual That has a cable for an external source, mine does not have that. Anyone installed it after the fact? Lots of plastic to take off to remove the radio, so I would like to have a solid plan before I start. Link to comment
Perk1975 Posted May 21, 2014 Author Share Posted May 21, 2014 I found this thread that appears to answer my questions Link to comment
Pletch Posted May 22, 2014 Share Posted May 22, 2014 Perk, The link you have is the same one I used. I have a Starcom 1 digital comm system. I used the information in that link to tie the rear speaker output into my comms. While the plastic was off, I installed the aux cable (bought at teh dealer for a decent nickle) and routed it up the forward edge into the CD compartment. Set up like this I can use either iPad or MP3, as well as adjust output and volume from the handle bar controls. Works perfectly! Just and option. Dan Link to comment
RT_Jim Posted May 23, 2014 Share Posted May 23, 2014 On my bike, the connector for the USB or iPod is in the glove box. If your radio doesn't have this, I'm sure its just a (expensive) connector to the radio. Check one of the online part fiche sites and you should be able to find the connector. Jim Link to comment
Perk1975 Posted May 23, 2014 Author Share Posted May 23, 2014 Thanks Jim I found this thread http://bmwsporttouring.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=331654&page=1 link You are right, its an expensive part with an expensive tool needed. Link to comment
