blackyam Posted May 28, 2014 Share Posted May 28, 2014 Hi, everyone. What would you use for safety if you had to stop on the side of the road, say to plug a tire? Would you use road flares, a safety triangle, or what? What do you carry on your bike that's not too bulky, yet is effective? Thanks in advance. ---John. Link to comment
TF1200RT Posted May 28, 2014 Share Posted May 28, 2014 I carry 6 road flares in the bottom of my bag on my R12RT along with my tire repair kit, Slime air pump and my first aid kit. Link to comment
eddd Posted May 28, 2014 Share Posted May 28, 2014 I would rely on my four way flashers, but if you wanted something additional flashing bicycle safety lights are small, light, and bright. Link to comment
Selden Posted May 29, 2014 Share Posted May 29, 2014 I made a safety triangle from reflective tape, stuck inside the lid of my (home-made) top case. It's highly visible, and takes up no space: Link to comment
Danny caddyshack Noonan Posted May 29, 2014 Share Posted May 29, 2014 This LED Flare It is seriously bright and doesn't have any perchlorates! That's the bad mojo in flares. Link to comment
eddd Posted May 29, 2014 Share Posted May 29, 2014 This LED Flare It is seriously bright and doesn't have any perchlorates! That's the bad mojo in flares. That one is a good size, but others that might look similar are much bigger. We used some on a trail basis with the fire department, and the ones we used were maybe 8" in diameter and 4" high. They were also a bit heavy to keep from being affected by passing traffic. Those were OK on the fire truck where we had room in a compartment. Just be sure to check the sizes and weight. Link to comment
dirtrider Posted May 29, 2014 Share Posted May 29, 2014 Evening John I guess I'm in the Or What crowd. No way would I lay on the side of a road to plug a tire without a blocking car or truck angled behind me. Just too many drivers fixate on flashing lights or parked vehicles & drive right into them. You see it on the news about every other night. For a quick roadside stop (where I can keep an eye on approaching traffic) I usually just use the emergency flashers or even a flashing turn signal. For anything more I wait for a blocking vehicle or nurse the bike to a safer place to work. Link to comment
areyouolsen Posted May 29, 2014 Share Posted May 29, 2014 I like that! Good idea! I made a safety triangle from reflective tape, stuck inside the lid of my (home-made) top case. It's highly visible, and takes up no space: Link to comment
tallman Posted May 29, 2014 Share Posted May 29, 2014 I carry one like this wearable strobe. that can be placed anywhere or actually worn. Works great in fog/dark/rain. I also carry small programmable bicycle red light LEDs. It can be placed or worn. Combined with 4 way flashers, retroreflective on bike and gear, I have a lot of options w/very little additional weight/space. Caveat is as pointed out, some drivers fixate. Link to comment
Bud Posted May 29, 2014 Share Posted May 29, 2014 I have 2 like in Tim's photo. Had them on the life jackets: ARC C strobe. Never thought of throwing one on the bike. Great idea! Thanks Tim Link to comment
blackyam Posted May 29, 2014 Author Share Posted May 29, 2014 Thanks for all the responses. I really like the battery-operated strobe options. D.R., you make a good point about fixation. I'll keep that in mind. It's scary out there. ---John. Link to comment
