CWD Posted June 10, 2014 Share Posted June 10, 2014 Anyone tried this stuff? http://www.ride-on.com/motorcycle-formula-mot.html Good or bad experience? I had a very experienced Honda tech tells me he swears by it. Link to comment
Bill_Walker Posted June 10, 2014 Share Posted June 10, 2014 I've been using it for years. As far as I know, it's never done anything for me, i.e., I haven't had any punctures that it sealed, but it hasn't hurt anything, either. It does make tire changes a bit messier. Link to comment
CWD Posted June 10, 2014 Author Share Posted June 10, 2014 Thanks, Bill. Do you think it helped with balancing? Link to comment
Bill_Walker Posted June 12, 2014 Share Posted June 12, 2014 No idea. I always get my tires balanced anyway. Link to comment
JR356 Posted June 13, 2014 Share Posted June 13, 2014 Here is what Ride On says about their product and supplemental balancing: http://www.ride-on.com/images/stories/pdf/should-tires%20be-balanced%20-tsb-07-26-12.pdf I use the product and feel that is does a good job balancing,but mostly use it for the safety factor. JR356 2005 R1200GS Link to comment
Lighthiker90 Posted June 13, 2014 Share Posted June 13, 2014 I have used it both front and rear. The shop was a Yamaha dealer and couldn't balance my tires when they mounted them on the rim. Balance is the same as with the old conventionally balanced tires. I can't speak about seals. It does hold pressure well, but as mentioned the other tires were old. Link to comment
GordonB Posted June 14, 2014 Share Posted June 14, 2014 My personal experience, it only works in a very narrow band of the center contact patch. My two punctures (with ride-on) were just outside the area. Looking back, most punctures I've received have all been 'just outside' this area. Link to comment
Bill_Walker Posted October 12, 2014 Share Posted October 12, 2014 I've been using it for years. As far as I know, it's never done anything for me, i.e., I haven't had any punctures that it sealed, but it hasn't hurt anything, either. It does make tire changes a bit messier. Let me update that report. Today I was out in the garage and happened to glance over at the set of tires I took off my RT right before the UN because I didn't think they had enough miles left. I guess the light was just right and something inside the rear tire caught my eye. Upon closer inspection, I found this inside the rear tire: That, friends, is the business end of a screw, protruding a good 1/4 inch into the tire! On the outside of the tire, it looked like this: That's pretty well worn down, so it had been there for a while. Two things: 1) Ride-On tire sealant works very well. The tire never lost any air. 2) I need to get a lot better about inspecting my tires! I'm sure glad I decided that tire didn't have enough miles left for the trip to Idaho! Link to comment
