AnotherLee Posted June 20, 2014 Share Posted June 20, 2014 Yes, I know there's a different number of points, but what's the difference in use? Why do they make the two kinds? Tnx- Link to comment
dirtrider Posted June 20, 2014 Share Posted June 20, 2014 Evening Lee The big difference is the way the socket grips the nut. In a "good" quality 6 point the socket grips the nut on either side of the nut points farther from the peaks so it grips the nut with a little more drive than the shallower notches of the 12 point. For hard to remove or high torque situations the 6 point is usually stronger as the 6 point socket has more meat in the side walls & deeper notches that grip the nut more securely. The advantage to 12 point sockets is they are easier to clock on the nut (more starting places) & as a rule thinner walls so they will usually go into smaller openings. The 12 point is also good for square nuts (4 points) & obviously needed for 12 point nuts. The 6 point is usually stronger with more nut grip so is less likely to round the nut off. My socket of choice for most auto/motorcycle uses is the 6 point but a good set of 12 points are handy at times due to the thinner walls or sometimes deeper center. Link to comment
smiller Posted June 20, 2014 Share Posted June 20, 2014 All of that, plus... it's a way to have more tools! Link to comment
Selden Posted June 20, 2014 Share Posted June 20, 2014 Thanks, DR. It never occurred to me that since 12 is divisible by 4, a 12-point socket can be used on a square nut. Link to comment
UberXY Posted June 20, 2014 Share Posted June 20, 2014 I usually do not use 12 pts unless I have a limited access problem. Link to comment
