DaveTheAffable Posted June 25, 2014 Share Posted June 25, 2014 I've been spending money...lol. I ordered a Spark Plug Coil removal tool, and an Oil Filter wrench from Marc Parnes a couple days ago. Quick delivery and... wow... quality machining, fit, finish. They both work as advertised. Twice this week I'm a happy guy... Link to comment
Rougarou Posted June 25, 2014 Share Posted June 25, 2014 I thought I needed something special to pop off the plugs so I went to my local dealership. I told them I was changing plugs and asked if they had the "special tool" to do it. The tech asked me if I had some 90* pliers, of which I said I do, he then told me to use those as that is what they use in the shop. So, I saved a couple of bucks. The tines fit right in the grooves and a slow straight pull does the trick. Mine are similar to these but of the standard size. Link to comment
hopz Posted June 25, 2014 Share Posted June 25, 2014 I really hate to expose myself to derision, but I use the BMW supplied puller that came in my tool kit... '05 R1200RT… the price is right, it works and I do not use it very often anyway. Link to comment
Selden Posted June 25, 2014 Share Posted June 25, 2014 Thanks for the 90° pliers tip. I still have 2 of the OEM spark plug cap pullers, but it's always good to have a backup plan. Link to comment
Joe Frickin' Friday Posted June 25, 2014 Share Posted June 25, 2014 I really hate to expose myself to derision, but I use the BMW supplied puller that came in my tool kit... '05 R1200RT the price is right, it works and I do not use it very often anyway. My 2009 R1200RT did not include a puller. I bought the Parnes one; it works well, but you need to be careful to use the correct technique. Link to comment
DaveTheAffable Posted June 25, 2014 Author Share Posted June 25, 2014 Well... I never knew that BMW RT's came with a spark plug coil removal tool. That might be because they don't... any more. But I have learned that they used to! Anyway, I should give better disclaimers to my reviews. I also forget that there are "Noobies" around that don't always have the whole story/history. Let me try again. ---------------- I've been looking at how one removes a spark plug coil from a 2010 RT. A lot of opinions out there. It seems that the coil is fairly easy to break. Methods for removal include: - Finding the older plastic tool BMW used to include - Buying one for $90 (?) at a BMW dealer - $15 metal one from ebay - A $30 machined aluminum one from some guy name Marc Parnes - A screwdriver used alternately left, right, left, right, gently prying out - Pliers - Needle nose pliers - 90* needle nose pliers - Delrin flat bars (A flat little alignment tool made of Delrin/Nylon) - Wooden tounge depressors - Chopsticks - "Gently yank on the wire and you'll be ok" (uhhh...no) It seems that in the end, it should be simple, but I learned that any method you use needs to be done with caution as the coils do break. It may be expensive, but I used to work in a machine shop and kind of like "machined things" and settled on ... .... a Spark Plug Coil removal tool, and an Oil Filter wrench from Marc Parnes a couple days ago. Quick delivery and... wow... quality machining, fit, finish. They both work as advertised. They included instructions and precautions on use, and also suggested using a little silicone (non petroleum!) grease on the coil boot to aid in future removals. Link to comment
