bwr Posted July 11, 2014 Share Posted July 11, 2014 I have three bikes that I will be removing front wheels from in the future (they're not all mine): '13 F800GT, '14 R1200RT, and '14 R1200GS. Does anybody have any suggestions for an affordable front wheel stand that will support the front end when pulling the wheels from these bikes? All my previous motorcycles allowed removal of the front wheels without a stand. Thanks. Link to comment
biometrics Posted July 11, 2014 Share Posted July 11, 2014 The R1200RT should be so well balanced on the center stand that you can weigh down the rear end (I use a rope tied to a cement block) and it will just sit there while you do your thing on the front end... make sure to chock the rear wheel so you don't roll off the center stand. I have successfully used this type of stand for other bikes in the past: http://www.ebay.com/itm/NEW-SPORT-BIKE-MOTORCYCLE-WHEEL-LIFT-FRONT-FORK-STAND-RACE-TRACK-STAND-/231269327711?pt=Motorcycles_Parts_Accessories&hash=item35d8b9e35f&vxp=mtr -John Link to comment
russell_bynum Posted July 11, 2014 Share Posted July 11, 2014 The R1200RT should be so well balanced on the center stand that you can weigh down the rear end (I use a rope tied to a cement block) and it will just sit there while you do your thing on the front end... make sure to chock the rear wheel so you don't roll off the center stand. Yup. I've done that with basically anything that has a centerstand. Otherwise...I like PitBull stands like this one. Link to comment
Joe Frickin' Friday Posted July 11, 2014 Share Posted July 11, 2014 The R1200RT should be so well balanced on the center stand that you can weigh down the rear end (I use a rope tied to a cement block) and it will just sit there while you do your thing on the front end... make sure to chock the rear wheel so you don't roll off the center stand. My R1100RT didn't require any weight on the rear end; removing the front wheel was enough to cause it to settle onto its rear wheel. That's what I call well-balanced. My R1200RT requires a good 50 pounds of extra weight on the rear end to get the front wheel to come up off of the ground. Not what I call well-balanced. Link to comment
eddd Posted July 11, 2014 Share Posted July 11, 2014 You might want to consider something like I put together. It is very versatile for working on either end of most any bike. I recently used this when changing the rear shock on an FJR demonstrating that it is strong. It also comes apart for easy storage. It hangs neatly on a wall taking up almost no room at all. Link to comment
GRB60 Posted July 12, 2014 Share Posted July 12, 2014 I just helped a friend pull the wheels on an r1200rt for a tire swap. Use the center stand then use lumber under the oil pan to support the front. No stand necessary. The oil pan is plenty strong. The fork leg shape makes it a little tough to use a stand anyway. Link to comment
Over Posted July 13, 2014 Share Posted July 13, 2014 I have the same type of stand recommended by Biometrics. I did rig up some ratchet straps to the garage roof for one change,but the stand makes it much easier and although it's another bit of clutter in the garage, IMHO its a safe and easy option. Link to comment
