Bob Boro Posted September 16, 2014 Share Posted September 16, 2014 Anyone install a Kisan headlight modulator or another brand on their R1150RT? Any problems? Where did you splice into the high beam wire? Within the headlight compartment or somewhere else? Plug-n-play? Link to comment
moshe_levy Posted September 16, 2014 Share Posted September 16, 2014 Here's how I did it on mine... Kisan Install on R1150RT Link to comment
tallman Posted September 16, 2014 Share Posted September 16, 2014 Oil, saddles, tires, yep, I forgot headlight modulators... Link to comment
Bob Boro Posted September 17, 2014 Author Share Posted September 17, 2014 Thanks Moshe!! I'd rather use the high beam but trying to splice in that tight spot is too difficult. Although the low beam modulation will always be on. I could splice into the sensor wire and add a switch but I probably won't. Thanks! Link to comment
moshe_levy Posted September 17, 2014 Share Posted September 17, 2014 Hi beam is way too much effort, not enough benefit. The way I did it is simple, easy, and works just fine. -MKL Link to comment
ESokoloff Posted September 18, 2014 Share Posted September 18, 2014 I know I installed a Kisan on my 03 high beam & I'm sure I spliced it in but can't remember the details as it's been 11+ years ago. Link to comment
Tri750 Posted September 18, 2014 Share Posted September 18, 2014 On the sensor wire, you don't need a switch. I wire tied a rubber brake bleeder cap to the sensor cable and when I want to disable it, I slip the cap over the sensor tip. The BMW bleeder caps as we know are tethered to the bleeder so the wire tie goes thru the rubber loopy thing. Link to comment
algover Posted September 18, 2014 Share Posted September 18, 2014 I used the Kisan on my R1100RT. I don't remember exactly where I spliced in, but likely at the closest point. I remember it was pretty simple. However, after a while I just stopped using it, and never got one for my R1200RT. I found the cagers often thought I was a LEO; the way their car headlights modulate. I didn't want anyone to think I was trying to "impersonate" a LEO. Link to comment
moshe_levy Posted September 19, 2014 Share Posted September 19, 2014 That's the best part - the left lane parts like the dead sea because they think you're a LEO. BTW try finding one that works "plug and play" for the R1200RT - you won't have an easy time of it. Kisan's certainly doesn't work. It was one of my first R1200RT projects and I came up empty handed. Nobody has a connector that just plugs in place - BMW's using a proprietary connector, unfortunately. So there's no plug and play available to my knowledge. -MKL Link to comment
Jagman Posted September 19, 2014 Share Posted September 19, 2014 I love my Kisan headlight modulator. Looked like it might be a tad difficult so I had my dealer in St. Louis, Gateway BMW, install on the bike. Works on my high beams like a charm. But they did say that they didn't think the taillight one was going to work out, and to let them know if I got it to work. Link to comment
pmurphy Posted September 19, 2014 Share Posted September 19, 2014 Check again. They reinvented the RT connector, and it has been working fine for me for the last couple of years. Shoot them an email; They will sell you just the new connector and you can retrofit. Link to comment
moshe_levy Posted September 22, 2014 Share Posted September 22, 2014 No kidding! That's great news! Yes, installing one was one of my first projects in Feb 2010, and after hitting the wall, I gave up. I even enlisted the help of my company's engineering team to come up with a connector to help Kisan, but we were not successful. VERY glad a solution has been found! -MKL Link to comment
Bob Boro Posted September 24, 2014 Author Share Posted September 24, 2014 Moshe: I bought the P75W(?) single splice headlight modulator. It's a new model they have. I spliced it into the white wire coming from the multi-switch on the left handlebar. It was an easy install and accessible for easy replacement should it ever fail. High beam modulates great! Link to comment
moshe_levy Posted September 25, 2014 Share Posted September 25, 2014 Very good! Glad to see they came up with a solution. -MKL Link to comment
