narcosis Posted October 5, 2014 Share Posted October 5, 2014 After updating everything in the Navigator V unit with Garmin Express I wanted to plan a route for a trip I'm going on. I downloaded Garmin BaseCamp and became a bit frustrated when trying to alter a route that it generated. Found this very useful 3 minute YouTube video to create a route in Google Maps, download a KML file, import that into BaseCamp and into your Navigator V: Much easier to create routes in Google Maps IMO. When you get to the export function in BaseCamp, select BMW Motorrad Navigator V as the export destination. It will automatically put it in the correct place in the Internal Storage folder. After you get the Nav V unit back on your bike, find your route in Apps -> Trip Planner I'm sure there are other ways to skin this cat but this works pretty well. Link to comment
ArmyGuy Posted October 5, 2014 Share Posted October 5, 2014 Nice. That's how I do it as well. Must check all the 'turns' though once it's in Base Camp. Sometimes, BC will try to make you do U-turns that don't make sense. Link to comment
dirtrider Posted October 5, 2014 Share Posted October 5, 2014 Nice. That's how I do it as well. Must check all the 'turns' though once it's in Base Camp. Sometimes, BC will try to make you do U-turns that don't make sense. Afternoon Mike Yes, that is one of the big disadvantages of building a route in another mapping program. It (Google Maps) works OK for simple main road somewhat direct routes but leaves a lot to be desired when making complicated routes on smaller back roads. About the only way to get a (useable) complex route to work on a motorcycle GPS is to import it into BaseCamp, then a do recalculate in BaseCamp, then go over the route with a fine tooth comb & correct all the little errors. By the time you go through all that it is actually easier & quicker to just build the original route in BaseCamp to begin with. For someone that just wants a get-you-there uncomplicated route then Google Maps will work but it just doesn't work good on complicated routes that you need to remain exactly as they were built without a LOT of work & fiddling. Link to comment
narcosis Posted October 5, 2014 Author Share Posted October 5, 2014 Thanks dirtrider. You inspired me to give BaseCamp another go. Once I figured out to turn off Avoid Major Highways (Options-> Activity Profile-> Road Type Avoidances), building a complex route wasn't too bad. BaseCamp was plotting every side street imaginable until I turned it off. Link to comment
dirtrider Posted October 5, 2014 Share Posted October 5, 2014 Evening narcosis A good way to do that is to set up multiple Activity Profiles-- Like-- motorcycling minor roads motorcycling minor roads avoid dirt roads motorcycling dirt roads avoid major hi-ways motorcycling no avoidances ETC With "Avoid Major Hi-ways" as your only profile you will have one dickens of a time forcing a route to stay on a major hi-way without forcing you off at every other exit. The latest BaseCamp allows you to use the function of multiple profiles on the same route. I have a specific profile for off-road routing as well as some different verities of avoidances for other route building. Base Camp is very versatile once you understand it's little oddities. Link to comment
