Hank R1200RT Posted October 10, 2014 Share Posted October 10, 2014 I recently acquired and installed a "BMW Supplemental LED CAN-BUS Brake Light", P/N 71602296553 from A&S. Their description says "To get the attention of the driver behind you, it flashes quickly four times, then remains lit in a super-bright steady state until the brake is released". However...super-bright, yes, but no flashee on my 2013 RT. Sent a note to A&S about three days ago, no response yet, so I am wondering if their description is incorrect. Here is the link: http://www.ascycles.com/detail.aspx?ID=55804 Looked at the same item on Sierra and their description did not say anything about flashing. Does anyone have these installed on a CanBus machine? Do yours flash? Did you install it yourself? Inquiring minds want to know. Note: searched the boards, but didn't find anything - apologies if this has already been answered. Hank Murphy 2013 BMW R1200RT "Gretchen am Spinnrade" Link to comment
The Rocketman Posted October 10, 2014 Share Posted October 10, 2014 Did you get the "Model-specific harness required, sold separately." noted on their site? Link to comment
6speedTi Posted October 10, 2014 Share Posted October 10, 2014 I have one on my 2012. It flashes very quick;y for about one second then goes bright. Just make sure you ordered the correct harness for your model and year. It is pretty much a plug and play once you sort out the installation of the harness. Link to comment
dirtrider Posted October 10, 2014 Share Posted October 10, 2014 Morning Hank You might try calling A&S to verify you have the correct light for your 2013 can-bus bike. Max lists that 71602296553 for the non can-bus bikes. Added: Max shows the 71602296555 for the 2007-2013 (K2X and K4X only). BMW XT-4 LED Brake/Tail LED for CAN-bus models. I believe you 2013 1200RTW is a K52. Link to comment
Hank R1200RT Posted October 10, 2014 Author Share Posted October 10, 2014 Dirt rider -My mistake on the part number -box says 71 60 2 296 555. Correct harness was included in the box. Do you have one of these? Rocketman - yes, correct harness was ordered. Do you have one of these on any of your bikes? 6 speed - yes, you are right about the installation, no real way to mis-connect the harness. I have checked this by pulling on the front brake with a bungee cord while behind the RT - supplemental light is on, brightens when brake light goes on, no flashing observed. I will see if I can have someone check over the weekend. Hoping there is something I have overlooked - $180-ish for four LEDs is steep - may have to pop for Hyperlites instead... Best regards, Link to comment
lkchris Posted October 10, 2014 Share Posted October 10, 2014 It flashes, but a more descriptive word might be flickers. Still an attention getter IMHO, which is the intent. Link to comment
dirtrider Posted October 10, 2014 Share Posted October 10, 2014 Dirt rider -My mistake on the part number -box says 71 60 2 296 555. Correct harness was included in the box. Do you have one of these? Afternoon Hank No, I make my own LED supplemental brake array. I don't like flashing brake lights so mine just comes on about 1/2 brightness with the tail light then goes to full brightness with the brake apply. Link to comment
ESokoloff Posted October 10, 2014 Share Posted October 10, 2014 ......... I will see if I can have someone check over the weekend. I'm just down the road from you (WLV). Got a 3 day wknd starting now. Let me know if you need a set of eyes. [Hijack] Did you hear, see, feel the F-15 yesterday?!!! [Hijack/] Link to comment
Fubar Posted October 13, 2014 Share Posted October 13, 2014 I have one on my 2012. It flashes very quick;y for about one second then goes bright. Ditto for my '09. I've heard you can add a resistor (?) in the line to slow down the flash. The LED's draw so little power that apparently it makes them flash exceedingly quickly. Link to comment
