AndyS Posted October 13, 2014 Share Posted October 13, 2014 Does anyone know if there is a forum dedicated to using the Garmin 590LM? If not, any other good resources? Link to comment
marcopolo Posted October 13, 2014 Share Posted October 13, 2014 Go to ADVRider.com and and try the "Layin' Down Tracks" forum. There's a long thread there on the Zumo 590. It starts right from when the unit was announced. http://www.advrider.com/forums/showthread.php?t=966727 Link to comment
AndyS Posted October 13, 2014 Author Share Posted October 13, 2014 Thanks. That is a good lead to follow. One issue I am trying to get to the bottom of is if you can use some temperature sender with the unit. If so, what! Link to comment
Stan Walker Posted October 13, 2014 Share Posted October 13, 2014 One issue I am trying to get to the bottom of is if you can use some temperature sender with the unit. Hi AndyS Short answer. I don't know of any way to get local air temperature info into the 590. Longer answer for us in the states. There is an ap that runs on the iPhone that allows the 590 to access and display weather info. The info is updated every 5 minutes on the screen. It works fairly well, but does require you to have cell phone coverage, not always available on back roads. As to temperature info I use a separate sensor and display mounted into that little hole in the panel intended for a radio display. Link to DROK display. The unit displays air temperature, TOD, and battery voltage. It's been modified to convert the TOD function into a runtime timer, and to be waterproof. Stan Link to comment
Stan Walker Posted October 13, 2014 Share Posted October 13, 2014 If not, any other good resources? Well, there is always me..... There is also the Zumo forum, it has a whole section devoted to the 590. http://www.zumoforums.com Stan Link to comment
kltk165 Posted October 16, 2014 Share Posted October 16, 2014 ZUMOFORUMS.COM is your source for everything Zumo. I've gotten a lot of good information from this site. Very helpful. Hope this helps! Link to comment
