Wiring a whelen TIR3 as a auxiliary brake light
Doug_Baliko
Doug_Baliko
I would like to add a whelen TIR3 LED light as an auxiliary brake lite on my '12 RT. I would like the light to be off until I hit the brakes. Is there a brake light wire to tap that is only hot when you hit the brakes?
Doug
Afternoon Doug
Basically, NO.
Your 09 hexhead uses a single wire for BOTH tail light & brake light with the tail light operating at a lower (pulsed/modulated) voltage (around 8 volts or so)
You can TRY your LED array as SOME will work on the pulsed BMW systems but even IF it works you will have the LED's running at a lower power for running light then go brighter for brake light.
If you insist on having it only work for brake light then you have to buy (or make) a transistorized circuit that reads the voltages & applies 12v to your array only when it sees brake light voltage input.
OR add a stand alone brake switches (usually a hydraulic switch at a banjo fitting) that uses brake pressure to apply 12 volts directly to your LED array.
Doug_Baliko
Thanks DR. I don't know if makes any difference but my RT is a '12 cam head not an '09.
Doug
Dave_in_TX
Doug
No, it doesn't make any difference.
