Guest Kakugo Posted September 28, 2015 Share Posted September 28, 2015 I am finding harder and harder to keep the RT wheels as clean as I like them. I don't know if it's due to the recent switch to nickel-free brake pads, the bike age and mileage or whatever, but getting rid of the dirt caked on those wheels is really getting hard, so much last time I resorted to the pressure washer to get at least a semblance of clean. I've tried a number of detergents but it seems things are getting worse with each new one, no matter how much I scrub with my trusty dish sponge. So... is there a product out there that can at least cut my washing time down? I am not asking for a "spray and hose down" product, just something that will work as wheel cleaner used to. Thanks. Link to comment
Boffin Posted September 28, 2015 Share Posted September 28, 2015 I use WD40 and a nylon bottle brush. Need to follow-up with detergent afterwrds, but the WD40 shifts the grime. Andy Link to comment
upfisk Posted September 28, 2015 Share Posted September 28, 2015 Baking soda and dish soap, mixed to tooth paste consistency. Scrip with a tooth brush and hose off when finished. Cleans our r12 wheels fine Link to comment
The Rocketman Posted September 28, 2015 Share Posted September 28, 2015 Diluted Simple Green seems to work OK for me. Link to comment
Williekiote Posted September 28, 2015 Share Posted September 28, 2015 have you tried S100? I've used it to clean most parts of the bike with good results. Link to comment
Guest Kakugo Posted September 28, 2015 Share Posted September 28, 2015 Thanks everybody. I've tried dish soap before and wasn't very impressed, even after a good brushing. I use kerosene to degrease the Honda rear wheel and swingarm: works like a treat but it's not up to the job on the RT wheels, probably due to a combination of completely different finish and different brake pads. I've used S100 products in the past and was far from impressed with them: the only one I still use is their waterproofing spray, and that's just because the shop had no other brands available. All-purpose industrial strength detergent looks like a good idea: at worst I can use it around the house. Link to comment
AlanS. Posted September 28, 2015 Share Posted September 28, 2015 Simple Green works fairly well. Link to comment
Guest Kakugo Posted September 29, 2015 Share Posted September 29, 2015 Simple Green works fairly well. We haven't got Simple Green here, but judging from the specs it's very similar to some easily available industrial all-purpose cleaners. I'll give them a try. Link to comment
PadG Posted September 29, 2015 Share Posted September 29, 2015 Anything wrong with using automotive foaming wheel cleaners? Link to comment
Guest Kakugo Posted September 29, 2015 Share Posted September 29, 2015 Anything wrong with using automotive foaming wheel cleaners? Too expensive... remember what they say about the cheapest part on a BMW? Link to comment
Mike Posted September 29, 2015 Share Posted September 29, 2015 Simple Green works fairly well. We haven't got Simple Green here, but judging from the specs it's very similar to some easily available industrial all-purpose cleaners. I'll give them a try. Make sure you dilute it. The undiluted stuff can mess up your wheels unless you remove it immediately. Link to comment
The Rocketman Posted September 29, 2015 Share Posted September 29, 2015 Even diluted, spray it on already wet wheels. Link to comment
Haynes Posted September 30, 2015 Share Posted September 30, 2015 Dirty rims have been a problem for me on my R1200GS-LC. I am seriously considering getting the wheels clear coated. Link to comment
WestyLancs Posted September 30, 2015 Share Posted September 30, 2015 My RT wheels seem to come up well using Wonder Wheels U, spray on, brush in, rinse off. The earlier version was quicker, but probably more damaging, if left on too long. The newer Wonder Wheels U, which is claimed safe for unlacquered wheels seems to work fine, and is available over here (UK) in most supermarkets. Link to comment
cris nitro Posted September 30, 2015 Share Posted September 30, 2015 I use Wesley's Bleach White. Works great. Link to comment
Guest Kakugo Posted September 30, 2015 Share Posted September 30, 2015 Thanks everybody. I bought of a jug of industrial strength cleaner. As soon as the RT gets dirty again (too soon!) it will be tested. Even if it doesn't work, i'll have something to wash the garage floor and my power equipment with! Link to comment
cris nitro Posted October 1, 2015 Share Posted October 1, 2015 Not sure what "industrial strength cleaner" you have, but I would be careful it doesn't stain/etch some of your finishes. Link to comment
Guest Kakugo Posted October 1, 2015 Share Posted October 1, 2015 Not sure what "industrial strength cleaner" you have, but I would be careful it doesn't stain/etch some of your finishes. Don't worry. 1)I asked for something that could be used on painted surfaces. 2)I am going to try it on a very small, incospicuous surface before using it on the wheels. Even if it fails the test, I have plenty of places around the shop to use it. 3)This is going to used on wheels and engine bottom alone 8after being tested obviously): the rest of the bike is still getting a very delicate Meguiar's shampoo. Link to comment
Chris K Posted October 1, 2015 Share Posted October 1, 2015 I use Mothers All Wheel Foaming Cleaner and a soft brush. Works great on both cast and spoke rims on my bikes. Link to comment
Skywagon Posted October 2, 2015 Share Posted October 2, 2015 Went to the mothers web site to read about the foam cleaner...had a disclaimer that says Do not use on motorcycle wheels, casings or components Suspect not harmful but afraid we might bust our arse and blame them. Link to comment
Lucky Dave Posted October 2, 2015 Share Posted October 2, 2015 Clean rags and WD-40. Once you use an aggressive cleaner that takes the smooth surface off the paint the wheels will get dirty faster and be damn near impossible to clean. Link to comment
PadG Posted October 3, 2015 Share Posted October 3, 2015 (edited) Clean rags and WD-40. Once you use an aggressive cleaner that takes the smooth surface off the paint the wheels will get dirty faster and be damn near impossible to clean. That is what I am afraid of, and that is why my can of foaming cleaner is still sitting on the shelf! Fortunately for me, the '15 RT's wheels have been very easy to clean with just the regular shampoo/water when I wash the bike. Edited October 3, 2015 by PadG Link to comment
RTinNC Posted October 5, 2015 Share Posted October 5, 2015 (edited) I use Griot's Garage Wheel cleaner but have also had good luck with S100 Wheel Cleaner that is more of a gel. Edited October 5, 2015 by RTinNC Link to comment
ElevenFifty Posted October 11, 2015 Share Posted October 11, 2015 Got a steam cleaner on sale from Harbor Freight last month ... first thing I used it for was my wheels ... did a great job. Link to comment
RTJohn Posted October 11, 2015 Share Posted October 11, 2015 I've been using Honda Cleaner/Polisher. Seems to work pretty well with all parts of the bike. Link to comment
Guest Kakugo Posted October 14, 2015 Share Posted October 14, 2015 Thanks again for all the replies. I haven't washed the bike yet because the weather here has been pretty foul and I'd like the bike to stay clean for at least a couple of days. We shall know pretty soon if that industrial cleaner does what's written on the tin because my bike is almost as filthy as my car... Link to comment
Ron_B Posted October 16, 2015 Share Posted October 16, 2015 I usually use Simple Green. A few times a year, when my wheels are really dirty, I use Windex. This is a bit controversial, as some say the ammonia in Windex is hard on aluminum surfaces. (I believe that some automotive wheel cleaners contain ammonia) It really cuts through the brake dust, and I've never seen any adverse effects on the wheel's finish. I just rinse off quickly, and am especially careful not to get it on painted surfaces. Link to comment
Guest Kakugo Posted October 16, 2015 Share Posted October 16, 2015 I usually use Simple Green. A few times a year, when my wheels are really dirty, I use Windex. This is a bit controversial, as some say the ammonia in Windex is hard on aluminum surfaces. (I believe that some automotive wheel cleaners contain ammonia) It really cuts through the brake dust, and I've never seen any adverse effects on the wheel's finish. I just rinse off quickly, and am especially careful not to get it on painted surfaces. If aluminum is unpainted, yes, it may etch and oxydize it. But on a painted surface it won't cause any damages Link to comment
Ride200mi Posted October 21, 2015 Share Posted October 21, 2015 Diluted Simple Green seems to work OK for me. Same here! Link to comment
Guest Kakugo Posted November 1, 2015 Share Posted November 1, 2015 I completely forgot to report back about my findings. The industrial cleaner turned out to be just what I was looking for. I used it at 10% dilution and it cleaned wheels, exhaust and engine just the way I wanted without ruining everything. It's relatively cheap and available locally hence a winner. Only problem... the wheels are now so clean all those small scratches and tear and wear signs really show up. Link to comment
RandyShields Posted October 22, 2018 Share Posted October 22, 2018 Slight deviation from an older thread. I am looking for a brush to clean the spoked wheels of my GS, as well as the wheels of my other vehicles. The brushes at the auto parts stores are nylon -- which I am afraid will be a bit scratchy. The online brushes are nylon or say they are soft, but don't describe the bristle material. Throwing this out to the collective wisdom of the board for brush suggestions. Thanks in advance. Link to comment
