DR Major Posted September 30, 2015 Share Posted September 30, 2015 I have 20s and wife has SMH10. Usually, I get an echo when we talk. She does not hear it. Suggestions? Link to comment
lkraus Posted September 30, 2015 Share Posted September 30, 2015 Is it your voice or hers that echoes? Or both? I know on the SMH10 there is a feature called sidetone. Much the same as speaking on a telephone, your voice is heard through the earpiece so you can modulate your speaking volume. You should be able to turn it off. Link to comment
DR Major Posted October 3, 2015 Author Share Posted October 3, 2015 Will look into that Link to comment
DKinsey Posted October 4, 2015 Share Posted October 4, 2015 I only notice the echo when stopped or off the bike. Link to comment
Tri750 Posted October 5, 2015 Share Posted October 5, 2015 Monday, just call Sena and they will give you the answer. Link to comment
DR Major Posted October 5, 2015 Author Share Posted October 5, 2015 Just got word from SENA tech support.. Sorry for the delay. If there is an echo, you will need to disable SIDETONE from the configuration menu setting. Different bikes, devices, and applications are going to output different levels of sounds and volumes. As for volume there is only one way on the Sena to adjust volume. You can easily adjust the volume by rotating the Jog Dial. You will hear a beep when the volume reaches the maximum or minimum level. The volume is set and maintained independently at different levels for each audio source even when you reboot the headset. For example, once you set the volume for mobile phone handsfree, it will not change even if you adjust the volume for your Bluetooth MP3 music. However, if you adjust the volume during stand-by mode, it will affect volume levels of every audio source. You can try to adjust the volume as well from the Garmin 660. Thanks and have a wonderful day! Sena Technologies Inc. Support Team > So, as I read this, if using the Garmin 660 and I set the volume to "5" and when talking with wife I set her to "7"- it will "mix" that ratio....??? Link to comment
