Doug_Baliko Posted October 30, 2015 Share Posted October 30, 2015 I'm mounting auxiliary lights and decided to use the mounts that are used for RTP emergency lights. I went with the Denali D4 LED lights. I have them mounted and I'm starting the wiring, which looks pretty straight forward. My only question is where is the best place to find and tap into the high beam hot wire? Thanks. Doug Link to comment
Kritou Posted October 30, 2015 Share Posted October 30, 2015 Where did you buy the mounts and did You have to modify the fairings in front of the mirrors? Link to comment
Doug_Baliko Posted October 30, 2015 Author Share Posted October 30, 2015 I bought the mounts and new inner mirror ring ( that has the hole pre cut for the post) from Max BMW. I probably could have cut the hole into the mirror housing myself with a Dremel. But I'm not sure that I could have done it so it looked good enough. If you're proficient with tools you could probably do it yourself. There is no modification to the fairing in front of the mirrors. Doug Link to comment
Doug_Baliko Posted October 30, 2015 Author Share Posted October 30, 2015 I found the high beam wire and the installation went smoothly. Doug Link to comment
JR356 Posted October 31, 2015 Share Posted October 31, 2015 Good choice on the D4's. I have them mounted up high on the crash bars on my 14GSA,similar height to your lights. Pretty impressed with the light output and the dual beam configuration is really useful here in the west where you can be on twisty tree lined roads one minute and wide open straights the next. JR356 Link to comment
Doug_Baliko Posted November 1, 2015 Author Share Posted November 1, 2015 A few more images: Doug Link to comment
elkroeger Posted November 1, 2015 Share Posted November 1, 2015 Where did you get that little USA sticker? My wife wants one. Link to comment
Doug_Baliko Posted November 1, 2015 Author Share Posted November 1, 2015 Where did you get that little USA sticker? My wife wants one. http://twowheelvinyl.com/index.php?cPath=13 Doug Link to comment
elkroeger Posted November 4, 2015 Share Posted November 4, 2015 Awesome, thanks guy. Already ordered a pair. :-) Link to comment
